Thread: Random Question but.....
    Regular Member adamtaylor's Avatar
    Witney (OXfordshire)
    Default Random Question but.....
    has anyone ever had to re-stick the rear view mirror to the windscreen? The one in my veccy has fallen off ! I have tried double sided tape but no use!! Any suggestions? Cheers!!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    you can get some propper mirror pad's from places like halford's i think, stronger better grip than normal one's
    Midlands Mod Shop - NFFC.
    Regular Member Cleeker's Avatar
    Oct 2007
    N Ireland
    You can get Loctite Glass Bond. 3 or 4 quid.
    Regular Member poves's Avatar
    lancashire
    Go to your local autoglass or rac autowindscreens , they will do it for not alot of cash , with the right adhesive , plus you get a guarantee if it comes off again.
    The stuff they sell aftermarket aint good enough mate.
    Hertfordshire
    I've not actually looked, but I am pretty sure the Vec doesn't use the sticky mirror pads.
    I'm sure you'll find the mirror should slide on and off of a bracket that is bonded to the screen.
    You could attempt to re-bond this yourself, don’t use superglue, use the proper stuff, glass bond as said.
    And be careful, it doesn't take a whole lot of pressure to crack a screen, probably a lot less than you may think.
    And without wanting to state the obvious, make sure you get it the right way up, because if it is upside you’ll probably break the screen getting it off, you may laugh, but I have seen this done more than once !
    If you are not confident, for what it is likely cost you, a few pounds no more, I’d take it to the experts, your local windscreen fitters like AutoGlass for example. They'll have the proper professional kit with all the correct primers etc.
    Edit: to slow, lol.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    mine fell off when i had window replaced, took it somewhere else and the previous people had used sticky pads!!!! so they used silicone like stuff and it has not come off since!!!
    essex
    i have heard that suprglue can crack he screen as it contracts!
    buy the proper stuff for a few quid, it consists of the correct glue and a very fine gauze that soaks up the glue so to speak and goes between mirror bracket and glass. only a few quid, loctite i think
    essex
  1. Bit of a random question really
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2013, 17:11
  2. Random Question
    By mungo1985 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2012, 19:46
  3. random remap question
    By lewisboss777 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2008, 18:19
  4. Random Boot Question!
    By pjames.79 in forum Bodywork & Interior
    Last Post: 16th April 2007, 23:56
  5. Random Music Question
    By AndrewTi in forum General Chat
    Last Post: 3rd February 2007, 22:34
