Thread: Advice
    scotland
    Default Advice
    Hi all
    new on here
    i am currently a member of astra owners club as i have a Astra MK4 2.2 sri, but i am currently looking to buy a vectra c sri 1.9D (150) so what i was wanting to know is there anything i should look out for when buying one and what are the common faults with this engine if there is any?
    thanks in advance
    Brian.
    engine faults are the same as the astra 1.9 150... the usual dodgy turbo/injectors/inlet manifolds/EGR valves..
    if you are going to get a 1.9 diesel, get a good warranty.. they are cracking engines, but some of them are utter dogs...now where near as reliable as the Z22SE...
    apart from that the vectra is well put together....
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    I am sure there are thousands of happy 1.9 owners, but it does seem that the engine does have "common" problems such as EGR & swirl valves, %-wise I dont know...I test drove a 1.9 (150) & was very impressed, you do get performance & economy, but the reported faults put me off.
    Jul 2006
    If you're buying used, check to see if it's had these problems already - swirl valve & inlet manifold should be fine once replaced with upgraded parts. EGR valve should be cleaned by the dealer.
    Clutch, flywheel and turbo are other less common, but disastrously expensive faults with the 1.9CDTi.
    If you get a good one, it's bulletproof. If you pick a bad one, god help you
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Get a 3.0 V6 - much more reliable
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
