Thread: brothers astra help
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    confused brothers astra help
    My brother has an 03 astra (not sure about engine size/type but think its a petrol). His EML keeps coming on and entering emergency mode. He had the fault code read and it came back with 'accelerator pedal'. He got a new pedal but it is just the same. Took it to vauxhall and they said they would need to try and change different things until the fault went away meaning they didn't know. Took it to another garage and they said they had known of this before but can't remember what the outcome was. He has now been advised (don't know by who) to scrap the car!
    Has anyone heard of this problem with astras and any solutions (apart from the scrapyard!)
    I have been told that the pedal box can play up. The ecu looses its signal for the throttle pedal position and throws a wobbly. Its a fairly common fault - so I was told when i had my 52 2003 plate astra coupe
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    any more ideas on this subject?
    Have you replaced the pedal box? What fault codes does it throw up? The actual number?
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    He has replaced the accelerator pedel unit but that didn't seem to do anything. He says the report from VX states
    'carried out tech 2 diagnostics. Traced fault to accelerator pedal potentiometer'
    so no actual codes. He's thinking about getting a reader as one garage said it has a few codes that won't clear!
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    He says the eml comes on after about 3 minutes most of the time now - told him about the paperclip trick but it doesn't work with his. Any other ideas?
    Quote Originally Posted by holtie View Post
    The accelerator pedal potentiometer would be the pedal box. Not the pedal itself. The potentiometer is how the engine knows what position the pedal is at. I would take it back to get it properly investigated.
  1. Just had this from neo brothers...
    By bigdave1701 in forum General Motoring Chat
    Last Post: 2nd March 2012, 22:22
  2. Brothers new car
    By S14RRJ in forum General Chat
    Last Post: 22nd April 2008, 09:27
