Thread: cleaning painted calipers
    Regular Member marky2027's Avatar
    Northumberland
    Default cleaning painted calipers
    Is there anything I can use to spray onto my calipers that I have painted with silver hammerite when cleaning the car?? Is it best just to use a thin brush and soapy water?? Will products like Autobrite wheel cleaner damage the paint finish?
    Sunny Dartmoor
    Hot soapy water should get the worst off or try some alloy wheel cleaner,just don't leave it on too long,good luck.......
    Jul 2006
    I give them a liberal dose of alloy wheel cleaner when I'm doing the wheels, then pressure wash the lot off. If I've got the wheels off at the time, I give them a quick scrub with a brush too.
    Tip: Get some sealant on them when they're clean, makes them MUCH easier to clean Autoglym Extra Gloss Protection works for me, but if you can get a proper wheel sealant that would be better
    i just spray megs APC on mine through the wheels then turn the Karcher on them..
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    What mark said, Meg's APC will work fine to remove most dirt, polish your wheels with a decent sealant or wheel wax and the dirt will fall away no problem
    Northumberland
    Cheers chaps
  1. painted calipers
    By mikejohnson90 in forum Styling
    Last Post: 18th June 2012, 22:51
  2. Painted calipers
    By rickit in forum Detailing and Car Care Discussion
    Last Post: 5th August 2009, 21:07
  3. painted calipers
    By paul.sessions in forum Styling
    Last Post: 10th July 2009, 20:27
  4. Painted Calipers
    By Danwells72 in forum Styling
    Last Post: 4th February 2009, 22:59
  5. Calipers painted mostly!!
    By parsco in forum Styling
    Last Post: 28th October 2008, 14:09
