Thread: CD70 Mono to Colour Screen
    Regular Member rjm_cdti150's Avatar
    Yorkshire
    Default CD70 Mono to Colour Screen
    Hi there,
    I currently own a 2005 Vectra C pre-facelift 150 CDTI. It has the CD70 with a mono screen. I am wanting to swap this to a colour screen and have been reading about the issues on here with regards to ebay and systems that have been removed from cars without the programming. Has anyone done/had a quote for a upgrade to a colour screen from Vauxhall? I know this would be expensive for the complete system, but as I already have satnav and the CD70 headunit, all I need is the colour screen and fitting. Has anyone any experiences with this?
    Thanks all.
    11 Post(s)
    According to Parkers, a colour screen in lieu of monochromatic display on a CD70 was £250 at time of launch. Probably a bit more now.
    you'll need to check the wiring, but you'll need the screen and a tech2 session to pair it to the CD70.. it's not a plug n play...and get a new ( or unpaired via tech2 'delivery mode' ) screen so you can be assured it will work..
    Yorkshire
    How much is a tech 2 session likely to cost? Thanks for the replies
    around £45..
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by rjm_cdti150 View Post
    around £45..
    that is the cheapest part
    you'll need:
    - a new display (CID): new... somewhere around 750 euro ; you can find them sometimes on eBay but you have to be sure that they are unpaired and come out of a vectra/signum otherwise they are useless;
    - the RGB-cable: dealer (part-Nr. 62 94 476, Art-Nr 13 185 491, around 60 euro) or eBay
    - a tech2 session at your dealer
    Apr 2008
    UK
    As everyone says obtaining the screen is the hard /expensive bit, but fitting it is a doddle and is plug and play.
    When you remove the old screen / vents you can then very easily threadle the RGB cable behind and down to the radio.
    The cable that plugged into the monochrome screen plugs into one connector on the new screen.
    Connect up the RGB cable to the other and te radio and it's time to navigate to your dealer!!!
    The other thing you may need is a different vent surround - I believe there are two different types one for mounting the monochrome screens and one for colour. no idea how much they cost as mine came complete.
    Paul
    Yorkshire
    So I emailed my local vauxhall dealer (perrys) and asked for a quote on a colour screen. Their reply:
    Hello and thank you for your enquiry
    Regards changing the screen , this is not a modification that we have carried out before and Vauxhall can not confirm if it can be done without changing the dash harness but to give you an idea of cost the screen alone = £1456.00 . if you wish us to investigate further please get back in touch
    Regards
    Has anyone got any idea what part number the colour screen is? With the price they have quoted, I presume that they are including the cd70 unit as well as the screen?
    Apr 2008
    UK
    I will take the screen out of my car over the weekend and get you the part number, but that price is consistent with what I was told.
    realistically need to find one that has been removed from a car the proper way, they do come up occassionally
    Good on Perry's for the response as my local dealership proved to be as useful as a chocolate fire gaurd
    Paul
    Yorkshire
    When you take it out mate would it be possible to take a few photos of the process to take the screen out. ie what order to unscrew things etc. Its appreciated mate, thanks alot for your help.
  1. Cd70/colour screen
    By tonyblade in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2013, 23:48
  2. Swap mono screen for colour in Signum
    By peterc2609 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 13:30
vauxhall vectra pre facelift colour screen
part number for cd70 colour
vectra c facelift screen
