Results 1 to 10 of 11
Thread: Help with painting
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    Default Help with painting
    I`m goin to have a go at painting my VXR diffuser myself so can some one talk me through the process of painting it with VX aerosols please? ie the various steps too go through from the primed state.
    Edit :how may VX cans needed?
    Regular Member Baz07's Avatar
    Lancashire
    These are the instructions i used...
    Painting instructions
    1. rub down spoiler p800 then clean
    2. 2 coats of primer
    3. leave primer to dry over night
    4. rub down primer with p800 then clean(can finish with p1200 is you wish)
    5. clean and dry then use tack cloth to remove all dust
    6. two coats of lightening silver leave to dry between coats(approx 5 mins)
    7. light coat of lightening silver from further away leave to dry (10 mins)
    8. DO NOT FLAT
    9. lightly go over with tack cloth
    10. several coats of laquer(first being half a coat for next coat to grip to)
    11.leave a couple of week to set fully
    12. flat lighty with p2000 to remove any imperfections(stay clear of edges)
    13. polish with rubbing compound like g3(not t-cut)
    14. polish job done
    Hope that helps in some way.....
    May 2007
    Sheffield
    It does
    Sunny Dartmoor
    Quote Originally Posted by Baz07 View Post
    Bet you don't Penfold...........:
    May 2007
    Sheffield
    Quote Originally Posted by glenboy View Post
    couple of weeks no problem , if the man says couple of days then a couple of hours is fine by me
    Sunny Dartmoor
    I'd be exactly the same........
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    or just bring it down here and i will do it for you mate paint and fit in a day
    Midlands Mod Shop - NFFC.
    May 2007
    Sheffield
    Quote Originally Posted by ditchp View Post
    Cheers for offer Rich , Just done it. Colour seems a little lighter but the bumper is a little darker than rest of car. However i think it`s perfectly acceptable , just got to get the exhaust rubbers replaced @ ExhaustsUK tomorrow (had to cut em off to get diffuser on) and maybe bring the tailpipes a tad closer together but on the whole i`m happy.Also need to polish in a week or two.Here s a couple of pics but bear in mind the exausts are now held on by industrial strength tie wraps
    Trim : Get a
    that look's awsome mate, top job indeed
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Looks Great & if the Tail pipes need to be further in when the New rubbers are fitted, You can always give the mounting brackets on the exhaust Cans a tweak
    Dean
  1. a bit of help on painting plz
    By veccy c in forum Styling
    Last Post: 6th March 2012, 10:45
  2. painting
    By G4GAV in forum Styling
    Last Post: 26th March 2011, 15:59
  3. House Painting & Decorating - Corner/Edge Painting advice
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 14th January 2011, 17:45
  4. Painting...
    By mickyblueyees in forum Styling
    Last Post: 28th May 2010, 21:49
  5. Painting help
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 22:26
