Results 1 to 10 of 21
Thread: engine oil Q?
    scotland
    Default engine oil Q?
    I believe the recommended oil for VX is 5w - 30 ,
    is it ok to be using GM 10w-40 semi on my 1.8 vec ?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i use vx's 10w/40 in my cdti mate, just change it every 10k i was told
    hth
    Midlands Mod Shop - NFFC.
    Regular Member wardy's Avatar
    Chichester
    Check the VXL web site. I'm sure it says 5W-30 for all Vec Cs. The 10W-40 is only listed for Vec Bs
    Lutterworth, Leicestershire
    confused Why??
    Quote Originally Posted by gsxrster View Post
    If the people who designed, developed and built the car say 5w-30, WHY on earth would you use something different???
    scotland
    Quote Originally Posted by abbeytec View Post
    what shaving gel do you use ? who recommended it ? how do you know its the right one ?
    there are a number of reasons people go for different oils so dont sound SO surprised
    using the 10W40 will be fine if you change it every 10,000 miles.....
    scotland
    sensible comments always welcome GSi
    Regular Member joewin1975's Avatar
    merseyside
    The 5w 30 is a better oil, it's fully synthetic as opposed to semi for 10w 40, plus it works better straight from start up and should last approx twice as long as 10w 40. But it's all down to opinion, people will tell you different things and different reasons why they choose there oil. If you drive hard and do a lot of miles then i'd say stick to 5w 30 but if you do use the 10w 40 as said before change after 10k...............
    I used the 10W40 for years.. it's fine in the 1800.. the 5W30 is really for the extended service intervals....
    scotland
    I'm around 10k a year , lots of it drivin like an old granny lol 2 under 5's in the car , so should be ok wi this then
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
