Results 1 to 10 of 11
Thread: big problem
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Default big problem
    hi can anybody help light that has the pic of a car and a spanner through it has come on also the drive is hellish and a lack of power also cruise control has stopped working . looks like my first trip into vx any ideas folks
    thanks dave
    Sounds like "limp-home" mode.... could be any number of things mate, I wouldn't even want to speculate!
    Ashington, Northumberland
    Definate trip to the stealer mate. It is indeed in limp home mode and will have fault codes stored. It won't let you use CC in limp home mode, just to further protect the engine. There really could be any one of scores of faults or combinations of faults.
    Jan 2006
    Hornchurch
    did you do ant thing to the car for it to go in to limp mode ?
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    have you tried it again since you switched off the ignition some times can be a minor fault (will be stored in memory) but not be present next time you drive
    worth a try!!
    Trim : vxr
    Mileage : 31000
    ye i tried that but i was hoping in tha morning it would be ok but knowing my luck it wont. the only thing i did do today was disconnect the battery to give it a charge as i think i am needing a new one
    Dec 2005
    In the sponge-monkey tent
    If you've removed the battery, check the fuses as there's a strong possibillity you've blown one when putting it back, it's easy done i did it when changing a radio once.
    Regular Member Matty H's Avatar
    Bristol
    Often it can simply be a blocked airflow sensor. I know two veccy owners who've had their car go into get you home mode because of this
    Regular Member CBR600FV's Avatar
    Wales
    If you have a 1.9 diesel then it could be the "water in fuel" warning. Try draining a bit off the bottom of the fuel filter.
    Trim : vxr
    Mileage : 31000
    thanks for your help guys checked out everthing but must be more than a simple fix let you know how it goes will phone vx tommorow get it booked in
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
