Thread: Rear Brake Discs
    Birmingham
    Default Rear Brake Discs
    Folks,
    Quick one for you, what thickness should rear brake discs be?
    Mine dont look too bad so contemplating whether to chnage but need to know if the thickness is about right. Like I say, all looks good, new brakes, discs look OK, so just down to thickness now.
    Let me know please.
    Thanks people!
    Much appreciated!
    Bye bye Vec B
    - Hello Siggy!
    Typically you can get two sets of pads to one set of discs, although the rears may not last that long depending on use
    Basically, if there is a groove clearly visible that the pad has worn into the disc then it's time to change
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    I use the rule of thumb, scored discs..replace, worn discs with a 1mm or more replace.. wear and tear fine...
    as these arnt cheap but in reality the only thing that stops you... worth the investment!
    New rear discs are............
    10mm if solid
    20mm if vented
    I would change either of them if they have a lip of more than 2/3mm
    Birmingham
    Thanks guys, didnt really notice any grooves in them so just left them as it started p1551ng down. Maybe next time. Will try to get a snap of them to show. I also have a spares set I took off one of my older cars, will have a measure and check the thickness! Thx again guys!
    Bye bye Vec B
    - Hello Siggy!
    Mileage : 000
    I have in the past gone on the way I drive. I get Two pad changes to a set of disc,s. But this now all depends on the composition of the brake pad and disc. I think that the Disc is made of a softer "cast iron" than they used to be, hence the disc wears down sooner. By the look of the discs on mine I would say I will need to change the disc,s and the pads both at the same time, rather than Two sets of pad,s use to a disc.
  1. What are my Rear brake discs size?
    By signum04 in forum Suspension, Wheels & Brakes
    Last Post: 4th May 2012, 18:07
  2. rear brake pads and discs
    By geebee007 in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2010, 01:40
  3. FS: Rear Brake Discs & Pads
    By gary k in forum Parts for sale
    Last Post: 16th March 2009, 11:23
  4. 2.2 rear brake discs
    By Wolf in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2008, 21:58
