Results 1 to 10 of 13
Thread: Help with reversing sensors (pics)
    Regular Member Paul66's Avatar
    May 2007
    Basingstoke
    Default Help with reversing sensors (pics)
    I have just fitted these rear reversing sensors. Went in a dream, help from the How 2’s was good. However my problem is the wiring, not being electrically minded and not having a manual, help is needed. I have taken photos and need to now which is the reversing light wire. Can any one help?
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    need another picture please. above the 3 long vertical plugs at the bottom u can see a ornage 40amp fuse, then a black plug and then a grey plug. from what i can see the reverse light (left) is on that plug.. Need a picture of that plug if you could please.
    says its a black wire, well thats helpful they all look black.. pin 12 it is... my money in on top right of the white connector block inside the grey one.
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    plugs are covered up in that one.. but i still go with my original statement as to what wire it is mate.
    May 2007
    Basingstoke
    Default extra pics
    these are pics close up of the upper and lower wiring
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i scotch locked mine the other end where the plug goes into the rear light!!!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    where to get the wiring from is actually in the how2 http://forum.vectra-c.com/showthread.php?t=11893
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Hi Paul, finally got round to fitting them then!
    I'll take a pic in the morning of the wire on mine for you.
    Regular Member wardy's Avatar
    Chichester
    None of the other posts on here with links are correct. They are NOT the estate model as you have. I have done the estate. Hang on & I'll post the correct link.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Quote Originally Posted by Paul66 View Post
    Paul,
    The pics you have there are from a hatchback/saloon.... Do you have an estate? if so then you need to connect here:
    http://forum.vectra-c.com/attachment...1&d=1188070669
    If you have any further questions, then give me a shout
  1. reversing sensors
    By markj23 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2011, 21:10
  2. fao... those with reversing sensors
    By paul.sessions in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 22:20
  3. reversing sensors HELP PLEASE
    By SRIRob in forum Styling
    Last Post: 20th January 2010, 14:43
  4. which reversing sensors please?
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 21:48
  5. Reversing sensors.
    By alb in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2006, 15:51
