Thread: Block Paving Driveway
    Regular Member denzo's Avatar
    Runcorn
    Default Block Paving Driveway
    Lots and Lots of road grease and salt on my nice newish blockpaving driveway
    Any suggestions on best way to clean and with what kind of detergent?
    I was thinking about jet wash in the spring with some swarfega driveway cleaner
    Any other thoughts?
    Regular Member R-man's Avatar
    Beds
    Your idea sounds perfect. I do my patio slabs with my neighbours jetwash, VERY time consuming but always comes up a treat. Before and after photo's could be nice... god I'm sad!!!
    If you have a Karcher, the DirtBlaster attachment works an absolute treat on paths/drives etc.
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    oil is a pain on brickweave driveways. Seriously I wouldnt leave it a minute more than you can and if it a direct oil spill I would sawdust it 24 hours before swarfega/ gunk driveway cleaner and pressurewasher. Buy a good bristle broom from B&Q as you can use this to agitate and foam the driveweay cleaner in.
    ps - make sure you move all your (and any neighbours) cars well away whilst pressure washing - as I dont know how splashed of driveway cleaner and thrown up salt/dirt/grime will react.
    Buy a bag of kiln dried sand and 24 hours after blasting the drive - empty the bag and brush all over to re-fill the mortar joints.
    Runcorn
    Thanks everyone ... no oil as such, just the horrible salt / dirt mixture the cars pick up from the road ... will wait until Spring.
    Yes I do have a Karcher
    Regular Member MLC's Avatar
    uk
    As mentioned by Kichpoo. Watch you don't blast out all the joints.
    Regular Member richardg3.2's Avatar
    Hull
    Be careful with the Karcher - they do clean them up well but as kitchpoo & MLC have said you want to try and avoid blasting the sand out of the joints as this is what keeps the sets stable. You are usually OK if you use the nozzle to give a fan spray and hold angle. Worth getting a bag of kiln dried sand anyway to reapply but it must be done when the sets are completely dry, just brush in with a soft sweeping brush.
  1. Pointing Paving Slabs..?
    By Rebellion in forum The 'Off Topic' room
    Last Post: 19th October 2012, 12:27
  2. New Driveway..
    By spoons in forum The 'Off Topic' room
    Last Post: 12th May 2010, 11:50
  3. Water on driveway
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2009, 09:42
  4. Driveway finished!
    By hudz in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 12:33
  5. new driveway
    By pogo in forum General Chat
    Last Post: 9th May 2006, 01:14
