Thread: buzzing noise
    Regular Member PeteRs's Avatar
    here or there
    Default buzzing noise
    i had a problem coming off a roundabout the car just cut out after few mins it started again but with spanner light it now makes a buzzing sound continuosly from the centre or rear of car as soon as ignition is switched on it buzzes any ideas as i think its electrical
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    might be something to do with the arial or alarm, have you tried doing different things to see if it stops? things like turning the radio on or setting off the alarm?
    here or there
    its loudest under the car no noise inside radio off still there was'nt doing it till it cut out at 50mph thinking it maybe fuel pump
    Jul 2006
    Northampton
    Trim : Sri
    mmm... have you tried finding exactly where its coming from?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i might be the fuel pump as i think its sit under the back seats
    Regular Member j13hdb's Avatar
    Nottingham
    It's not that push bike still wedged under the car is it Pete????????????????
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    We had a quick look at this today and are indeed suspecting the low pressure fuel pump.
    here or there
    thanks for looking at car Dean more money gotta be spent now
    ill have a go at changing it myself is it in the tank or on top forgot to ask thanks
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    Its actually inside the tank. Says procedure is roughly, 'remove rear seating bottom' peel back cutout in carpet. prise plastic access cover off. disconnect wiring. mark fuel hoses and disconnect (on quick release fittings), Using vauxhall special tool unscrew the lock ring ( will have to see what this special tool is), lift fuel pump cover away from tank until wiring can disconnected from the underside of the cover. remove fuel pump cover and collect the sealing ring from top of the tank... release 3 retaining tabs by pressing them inwards then lift the fuel supply pump out of the tank. Also check the fuel filter whilst its out too.. refitting is reverse of removal!
  1. Buzzing Noise
    By Wolfie01 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2011, 13:08
  2. Buzzing noise from speakers
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 17:59
  3. egr making a buzzing noise
    By wbm156 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 21:46
  4. "buzzing/crackling" noise
    By felixx in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2010, 15:52
  5. buzzing noise after i turn ignition off?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2007, 10:20
