Results 1 to 10 of 22
Thread: Valeo Automatic Lighting System
    Regular Member vectrabob's Avatar
    scotland
    Default Valeo Automatic Lighting System
    does any1 have or had any dealings with this product and is it worth while???
    http://www.lmfvauxhall.co.uk/store/p...at=1263&page=1
    Hertfordshire
    Each to their own, but personally, Iím quite capable of turning my own lights on and off thank you very much, lol.
    Anyway, the main thing you would need to check is if it is compatible with canbus wired cars, which I hate to say, it probably isn't.
    Jul 2006
    I'm quite good at noticing when it gets dark...
    Quote Originally Posted by LMF
    Poor visibility is a real anger for motorists
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    getting me thinking cap on here... maybe an output from one of their relays can switch the BCM module?
    gonna dive into the wiring for it... Not easily possible, the light switch tells the BCM to tell the UEC to turn the lights on.
    Hertfordshire
    Yep, I tried to find other ways to turn the lights on when I was looking at fitting my HID's, and I couldn't find any. IE you wonít easily pick up a fuse or relay somewhere that you can tap into. (would probably help if you had wiring diagrams, which I donít)
    It may be possible, but not easy and you may well end up looking directly at modules like .
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Ok, relooked yet again.. There is one line of attack i can see having an effect... Finding the line on the REC which normally tells the BCM it has received a signal from the rain sensors day/night section... still trying to trace exactly which line it is atm... in order for this theory to work it would need an autolight switch plus tech2, to enable it... thus bumping up the cost quite a bit... so might as well go the proper route maybe of rain sensor and wiring loom?
    2nd option pin 5 from the headlamp switch tells the BCM to turn on the lights... now the question is does this go high, ie 12volts?
    pin 11 is headlamp switch low reference.. maybe 0 volts?
    Looks like when the headlight is switched to dipped headlights it pulls pin5 down to low reference pin11. This could therefore be the point where the external relay could do this.
    SHOP is now shut for the night cause me heads hurting thinking about all this!
    scotland
    obviously not as easy as i thought it would be, sum things are to good to be true.
    Hertfordshire
    Dean, when I was poking around in the headlight switch before, I am certain it doesn't have anywhere near 12v as it doesn't actually switch any load, as you know, I am 99% sure it runs at 5v.
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    thus the ? mark against 12volts lol.. All i can figure out is that the line gets pulled low to activate dipped headlights.. voltage doesnt really matter to an extent. Its also got a resistor across it down to ground too, which is where i think it detects if the headlight switch is remove it losses this resistance and switches the lights on as a saftey measure. 5v could be right if its being run by cmos ic's in the BCM
    Regular Member L33AVN's Avatar
    West Lothian, Scotland
    Default harsh
    Quote Originally Posted by parapaul View Post
    that was a bit harsh dont you think?!
  1. Valeo Automatic Lighting System
    By Welsh_J_2000 in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2012, 07:50
  2. automatic lighting?
    By arkhan78 in forum Styling
    Last Post: 13th July 2009, 19:41
  3. valeo auto lighting
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2009, 18:09
  4. disable automatic lighting
    By urbanb in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2007, 00:39
  5. Automatic lighting
    By Leslie in forum Vectra C / Signum Troubleshooting
    Last Post: 11th February 2007, 10:44
