Thread: Aerial not working with aftermarket headunit
    Tadley, Hampshire
    Default Aerial not working with aftermarket headunit
    Hi,
    I've got a Fakra aerial adapter on my vectra c but the aerial appears to be dead. The adapter has 2 leads on the output side; the normal long aerial bullet and a tiny single wire clip. Should I be using this for anything?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I think the aerial has an amplifier fitted,try a 12v feed to the small lead that should make it work.
    Tadley, Hampshire
    Fantastic thanks. I did suspect that, but didn't want to blow it up!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    No probs,just fit a low amp fuse to start with,as you say you don't want it going pop!
    Tadley, Hampshire
    Should any 12v source do? ie, can I tap it from the headunit loom?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Yep the best one would be the power aerial lead from the new h/u,then it's only powered up when needed.
  1. Aftermarket CD70 Aerial.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2010, 01:20
  2. Aftermarket Headunit
    By mshaw in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2009, 10:28
  3. Vectra Aftermarket Headunit Help
    By jmacp in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2009, 21:35
  4. Wiring Question for Aftermarket Headunit??
    By Cilldara1 in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2007, 21:21
  5. Aftermarket Headunit
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2006, 21:56
