Thread: Pre warranty run out question
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Default Pre warranty run out question
    When I go over a small ridge/curb type bump I think I can hear my bush's or joints?? making a noise, like a sort of slight loosness sound not loud but I think you get my meaning. any how as the car is out of warranty end November, are the bush's/joints?? covered in this third year warranty?
    Any advise would be welcome.
    kc
    Book the car in now, that way it is recorded
    Once repaired those parts are under warranty for a further year
    As with the original warranty, book the car in for anything and everything
    After the warranty has expired you will be liable for any repair costs
    Regular Member Karl's Avatar
    Sunderland
    would bushes not be general wear and tear?
    No, I've already had the rear trailing bushes replaced on mine at 45K miles
    I've also had the rear brake discs replaced at last service, a claim for them as component failure, which resulted in new rear brake pads and discs
    Dec 2005
    West Lothian
    I hope that they see my worn bushes, if thats what they are as a warranty item. But knowing my lot would say its a consumable part.
    What I would like to know is is it a consumable part or were you lucky to have a garage that fitted it out of kindness etc.
    Jul 2006
    I think unless you've done well over the 60k miles the warranty allows, you should be in with a fighting chance.
    My Vectra is under warranty until Nov 2010, or 130K miles
    I have already checked and the only things I need to pay for are bulbs, tyres, exhaust, bodywork, and trim
    Everything else is covered
    My previous Vectra B was the same, and the rear suspension bushes on that one were replaced at about 110K miles, also on warranty
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If I was you I would get the MOT done before your warranty expires. That way any work needed doing is covered by the warranty esp the rear suspension arms. Thats what I did anyway which meant they had to replace my rear suspension arms and one of the track rod ends.
    Dec 2005
    West Lothian
    Quote Originally Posted by merikiito View Post
    Good idea. Think I will do just that and will try them on any possible repairs that may need done.
    You need to be careful with MoT repairs, as the warranty doesn't actually cover that unless you have the add-on for that section of the policy
  1. Warranty Question
    By Mcdermott in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2008, 13:39
  2. Warranty Question
    Last Post: 27th May 2008, 11:33
  3. Warranty question.
    By Stevel in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2008, 21:16
  4. Stealerships...warranty or no warranty, that is the question!
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 15:48
  5. Vx Warranty question
    By Paulmac07 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2006, 13:11
