Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: ESP/TC SWITCH installation
    bucharest, romania
    Default ESP/TC SWITCH installation
    hi, I have a problem, could you help?
    I own a vecta c 1.9 cdti 150 hp which, if you could believe, hadn't a ESP/TC switch.
    so, i've bought one and put it in his place, baut, surprise, not working
    could anyone tell me what's the problem?!
    I need so much to deactivate manually the TC!... especially now, when my car is remapped at 200 hp!!!
    pls, pls, pls!!!
    Full Member Big Sig's Avatar
    Its not always possible. Its like a 50:50 chance of the switch working. Unless it can be tech 2'd off?
    Mileage : 000
    There seems to be a bit of "luck of the draw" my 3.2 Elite did not have the switch, but the 3.2 GSI does. So I bought a switch, and mine doen,t work either, strange "eh", Mind you the switch looks better than a blanking plug.
    I have asked and they say it can not be Tech 2ed
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by ionradan View Post
    pls, pls, pls!!!
    tech2 is no option: if the switch does not work, it means the cable between the switch on the dash and the ABS-box "is missing"
    see this for more; and if your German is ok, here you will find the instructions to fit the missing cable between pin 3 of the ABS-box and the switch
    Regular Member Stu14t's Avatar
    Perth, Scotland
    I had ESP as a factory fit, with IDS+ but didn't get the switch . Had to retrofit the dam thing
    I think big Pete had the same issue also.
    Hertfordshire
    Quote Originally Posted by sig63 View Post
    My German is nonexistent, lol.
    Can anyone translate the basis of the PDF on there ?
    I've done this online but you know those translators leave a bit to be desired.
    There are pins in my switch socket so some wiring is there.
    I was just wandering what the relationship is (if any) between the connector block in the passenger footwell where it refers to pin 26, and the mention of pin 3 on the abs connector on the web page.
    For example if we have a wire in pin 26, is this the one to use without the need to go to pin 3 on the abs plug ?
    Also, both methods appear to refer to just one wire, obviously a signal wire, anyone know what the signal is, I would guess it just requires a momentary earth to turn TC on and off ?
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Pin 3 ABS module blue/red from the ABS ECU to X1 dash loom plug (pin26) via pins 5 and 6 on the TC switch exiting on the black/brown cable heading back along the X1 dash loom plug (pin25) on the brown wire down to a ground.
    Switch illumination is handled by pins 2 and 4 on the TC switch pin 2 being gray/yellow going to the BCM and pin 4 being a brown down to ground.
    Hertfordshire
    Oooohw sounds like you've sussed a bit of this already.
    Ok, that’s making my head hurt now, lol.
    Do you know exactly what pin is supposed to go to what pin, lol ?
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by Green Growler View Post
    The PDF, Fildabhilfe or Field Remedy 1508 is only useful for hatchbacks from MY 2002-2003 ! (Doesn't someone have this in English?)
    On these cars the switch was forgotten but the wire between pin 26 in the connector in the footwell and pin 3 in the ABS box is present.
    Other cars need to go directly from the switch to pin 3.
    You can test it by grounding pin 3: the orange lamp on the dash must come on - and/or if you think there is a wire present in pin 26: ground this one first.
    Hertfordshire
    Excellent m8, that’s exactly what I wanted to know thank you very much.
    I kinda figured as much, it certainly mentions exceptions for the estate, so most likely will have to go from scratch.
  1. Following on from the ECC Installation
    By paulhb in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2012, 14:24
  2. HID installation help please.
    By SillyMoose in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 20:54
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. ps2 installation.
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 10:22
vectra c esp switch
turn vectra esp off
vectra c esp
vectra c esp kytkin
vectra c esp button
vectra c esp switch removal
vectra c no esp button
vectra esp switch
luistoneston kytkin vectra c
vectra c install esp off
vectra c tc switch retrofit
vectra c esp activation
esp button vectra c
esp vectra c
