Results 1 to 2 of 2
Thread: My Signum Issuse
    Apr 2008
    SHeffield
    Default My Signum Issuse
    Hi Guys just to let you know what trouble I am having with my Signum 1.9cdti 150.
    It started with a oil leak on the crank shaft big end bearing, the seal was replaced twice under warrenty.
    Then after another 1000mile I have a problem with a noise clutch, which I thought was the thrust bearing.
    Vauxhall replaced the dual mass flywheel under warrenty. Turns out it is not the DMF but the gear box it's self....common fault by all accounts ??
    It also need a
    new manifold.
    new oil seal on the bottom crank pulley.
    new bottom crank pulley ( because certain ones can colapse )
    new roll bar linkages
    I am waiting for vauxhall to aurthorise the dealer to put a new gear box in it...
    I have done 55k from new and the car is not yet 3 years old
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Thats a lot needed?! Should all be done under warrenty to be honest! Hope it works out for you!
  1. Replies: 2
    Last Post: 6th October 2012, 23:09
  2. Replies: 5
    Last Post: 5th February 2012, 20:42
  3. Coolant leak issuse still here
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 19:06
  4. Stardard Stereo Issuse
    By Swifty in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2009, 19:58
