Results 1 to 10 of 11
Thread: troubleshoot spanner light
    Mar 2007
    Sheffield
    Default troubleshoot spanner light
    So the Signum (04 1.9 deisel) decided to give me a new icon today.
    After 3 or so minutes of driving, enough for the engine to get warm, the spanner comes on and kills my turbo.
    The car is running 5 to 10 degrees hotter than usual, not anywhere near enough to be concerned with though.
    Turn of the engine, immediatly start the car, and its another few minutes before it turns on.
    My mate has a el cheapo OBD2 Tech 2 USB reader and it reports NO error codes.....
    So im confuddled, has anybody had a similar issue.
    Had a new alternator fitted last week but this problems has taken a few days and over 700 miles to show its self so im not convinced its that.
    May 2008
    dunfermline fife
    Default spanner light
    my vectra c 06 cdti sri 150 has the same problem its been in the garage and did not show the error that caused the car to slow its going back in tomorrow ill let you know if i have any joy . my car has also done around 700 miles since the fault last showed up and it was running sweet till spanner light come on
    Wales
    One thing to consider is as with all these Vectra C's and Signums are all fully of different control modules and ECU's most of the OBD scan tools wont cover 90% of the control units, you need something like a TECH2 or similar device
    Mar 2007
    Sheffield
    had a mate with a snap on reader look at it, reported as air flow, yet mass air flow is still reporting correctly, gonna check and clean EGR valve, plus carb cleaner in the air flow meter as per a recommendation.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Could be boost sensor, i had this on my 2.2 DTi, cleaned it and been ok since (fingers crossed), dunno if would be the same on yours but worth a go HTH
    Wales
    Dont rate snap on scanners on anything new like these. Personal preference i guess.
    Would be worth just having a look in the surrounding areas where the alternator is to see if something has been disturbed or wires / plugs not seated correctly
    Birmingham
    On one of my previous CDTI's turned out to be be the boost sensor as well as the swirl valve.
    Bye bye Vec B
    - Hello Siggy!
    Mar 2007
    Sheffield
    well ive just located and cleaner the boost pressure sensor.
    Cant see that well onto all the pipe, gonna do some work, which I should be doing now, and come back to this tomorrow. peeing me off now.
    Mar 2007
    Sheffield
    more advice needed please....
    new MAF, new EGR valve and solenoid, cleaned inlet manifold sensor (boost pressure).
    Ive checked the hoses, and so has the AA guy and he says they are ok, "otherwise you would hear them"
    I cant feel a turbo boost, and after a mile or so the spanner light comes on. Drives ok besides this, but its totally gutless. A bit of smoke on hard accelleration.
    Any advice appreciated... im at the end of my teather
    yep, my best advice is to get it to VX or an independant equipped with VAUXCOM as these are about the best you will get to help you diagnose your fault and end the component chasing....it'll cost you £45 to get it read, but how much have you laid out already..
    come back with the codes and we can help you more..
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
