Results 1 to 10 of 16
Thread: new tyre question
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default new tyre question
    guys if i changed my original spec front tyres to 225/45 r17 would i have to put them on the back or could i put them on the front ok and then when i could afford it change the back ones to the same ones?
    Feb 2006
    Guttedsville
    Put them where you like bud.
    As long as the tyres on the axle are the same size, you've no probs. I put mine on the rear first, only because they had worn first.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Check with your insurance - when I put on a pair of 225's to replace 215's I was told my insurance that they had to go on the back.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Always the most tread to the rear,if they're part worns with equal tread as the 215's put the wider on the rear as they should have the most grip.
    11 Post(s)
    Quote Originally Posted by JuzzyD View Post
    Did they give a reason?
    Tyre rotation would probably be the reason
    New tyres on the rear, the existing rear tyre should then be crossed over and swapped over to the front
    However, it is only advisory
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    ^^If you have directional tyres you wouldnt be able to cross them over, as they'd be the wrong way unless you turned the tyres around on the rims.
    To answer the first question. It doesn't matter if the wider tyres are on the front or the back (though the back is recomended), as long as the tyres are the same on each axle.
    Hope this helps!
    Chris
    Quote Originally Posted by chrisschild View Post
    That would be obvious and required
    Although I did see a BMW today with both front tyres incorrectly rotated and a space saver on the offside rear
    Belfast
    General rule is new tyres on the back. Though Vauxhall specifically say new to the front...
    Jun 2006
    Somewhere...
    They just said that as they are wider they wanted them on the back.
  1. tyre question
    By CLOMP in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 19:56
  2. yet another tyre question
    By gordy07 in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2010, 08:34
  3. Another tyre question
    By dave300776 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 08:46
  4. Another Tyre Question
    By redraptor_141 in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2009, 22:29
  5. tyre question
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 22:33
