Results 1 to 3 of 3
Thread: throttle position sensor
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default throttle position sensor
    does anyone know how to check the throttle position sensor for faults using a multimeter, like what voltages i should be getting from what wires as i have got a good flat spot when the throttle is lightly pressed which seems to make the car kangaroo could this be the fault i wonder? ...the car went into vxl yesterday for diagnostics and no codes found
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Does it kangeroo if the cruise control buttons are used to accelerate?
    Standard sensors are really just a potentiometer and gives an analogue output. If it is the same on Vec, the output is usually between 0 and 5 volts depending on position. I seem to think that 0 volts is WOT.
    They would be easy to check on the vehicle, if you can get to the wiring, but I don't know which wire is the signal wire. You could easily find out though by using your multimeter and changing the acc pedal position.. It maybe that it needs a clean.
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    yes does it with cruise control on sort of speeds up and slows down a bit and jerks as it does it...dunno if this is normal I got a multimeter but dunno what wires i should be checking plus the plug is sealed so i cant get paperclips in the plug to test it while its plugged in
  1. Throttle Position Sensor Vectra Est. 2.0L DTI
    By bernadette in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 18:38
  2. throttle position sensor
    By Ryan in forum Engine & Drivetrain
    Last Post: 24th November 2010, 21:06
  3. Throttle Position Sensor
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2010, 15:12
  4. Throttle Position Sensor...
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 16th September 2010, 20:51
  5. Throttle Position Sensor
    By Kristypie in forum Engine & Drivetrain
    Last Post: 9th April 2010, 21:14
