Thread: Brake bulb warning light
    Surrey
    Default Brake bulb warning light
    My brake bulb warning light came on today so I checked the lights and all OK. Is there a known problem with the checking circuit?
    Glasgow
    Mines came on some months ago - genuine. Had never seen the thing before. Replaced faulty bulb. Came on again a week later - genuine, replaced the faulty bulb. Now it comes on every day for about twenty seconds. Checked every bulb and all fine. Haven't a clue why it shows so I reckon you may have something with the circuit.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    When a brake bulb goes another bulb in the cluster takes over its job. So it may look like they are working but one will be faulty. I had an inconsistent bulb check warning come one for ages. It ended up that the filament had come lose in one of the bulbs, so sometimes it worked and sometimes it didnt. HTH
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Best bet to change all the brake light bulbs then...
    Quote Originally Posted by joules2.0t View Post
    Huh? There are only two (plus the LED strip)
    However, as already mentioned, when one bulb fails, the one below takes over.
    Bulbs (all 12 volt 21 watt) from top to bottom in the light cluster:-
    Turn signal light
    Tail light / brake light
    Tail light
    Fog tail light (drivers side only - this is normal for the UK)
    Reversing light
    For the tail light a reduced voltage is supplied to the bulb (to make it dimmer) and when it becomes a brake light the voltage is increased to make it brighter.
    Also, if the upper tail/brake light bulb fails, then the lower tail light takes over as a tail/brake light.
    In short, just make sure the 2nd bulb down from the top is ok.
    Regular Member cat&sarah's Avatar
    Mar 2007
    Fermanagh / N Ireland
    Had the same problem just trial and error for me
    Surrey
    Good advise Dave...thanks. I changed the 2 bulbs and hey presto no warning.
  1. bulb warning light
    By woodze in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 12:24
  2. Rear brake light bulb warning won't go off
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2012, 21:39
  3. Bulb Warning Light...
    By Ross-SRi in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2011, 20:49
  4. Brake bulb warning light
    By SeeDeeXeye in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2009, 02:42
  5. Bulb warning light
    By mike12 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 22:23
https:www.vectra-c.comforumshowthread.php51573-Brake-bulb-warning-light
vectra brake light warning
vectra brake warning light
vectra c brake lights
vectra c rear light bulbs
vauxhall vectra brake light warning
how to replace break light on signum
Vectra c brake light bulb waning
vectra clear brake light warning
opel vectra c 2008 stop light
vectra c how to clear the bulb warning
cant get brake light warning to go off 2004 vectra
vectra c brake bulb
vectra c rear light bulb cluster
brake light warning on vectra
vectra c brake light warning
holden vectra 2005 break light warning
vectra c changing rear brake bulb
vectra break change tail bulb
vauxhall vectra brake light bulb
vectra c brake light on dashboard
vectra c brake bulb swap
vectra c stop bulb value wattage
brake light warning light vectra
rear light cluster on vectra c
