Thread: Empty fuse slots
    Regular Member C9_hardlatch's Avatar
    May 2007
    Default Empty fuse slots
    Hi all
    Whilst I was checking some bits on the car yesterday, I had a quick look at the various fuses in the car and noticed there are quite a few vacant in the rear fuse box. Some are completey empty ie no wiring behind it, whilst others have wiring but no fuse fitted. Of these, fuses 8, 12 and 17 are for rear seat heating and seat climate control, and fuses 15 and 16 front seat heating left and right are fitted.
    So first question, is it possible that my car (Signum Elegance 53 plate), has all the wiring and I just need to fit heater pads and switches for all systems go?
    Second question why do they fit fuses for options that the car doesnt have, like fuses 19, 26 TA and Twin Audio. Fuses 28 parking distance sensors.
    Also there is a 10A fuse in postion 25 in the rear box and a fuse fitted in position 4 in the front passenger compartment, the manual doesnt say what the are for, anybody know?
    Had another look today and popped of the blank switch covers, which revealed connectors behind them. Which seems to confirm that some if not all of the wiring is there for heated seats.
    Neil
    Regular Member shan's Avatar
    I don't know why they do it.
    I'm not sure what the plug under the hazard light switch is for ???
    I do know mine has all the wireing for the heated seats. Mine's an elegance also.
    I see you have the wireing for all the switchs.
    You should have the wireing for the front seats in the big plug under each seat.
    To check if the rear seats have the wireing to them.
    Push the seat all the way forward then lift the fold handle and as the bottom of the seat pops forward hold it down and push the back of the seat back. Under the bottom of the seat their is 2 plugs 1 will be connected "airbag" 2nd plug is for the heated seat.
    I'm planning on doing the heated pads in my half leather
    That's the sports button on the left isn't it...? Traction control and parking sensors on the right hand side...?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    It's parking sensors under the hazard lights and traction control and sport button on the right.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    the top right one is for heated seats i think!! the t/c is under the alarm
    Sunny Dartmoor
    Yeah top right and left are heated seats and you're also right vectragsi3.2 the t/c switch is under the alarm switch,here's the full line up.........
    http://www.vectra-c.com/forum/showpo...05&postcount=9
    May 2007
    Hi Shan
    Thanks for that, had a look see the attached pic, is that the connector you mean? If so looks like heated seats might be on the horizon.
    Neil
  1. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  2. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  3. empty fuel???
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 20:07
  4. Cam follower empty!!!
    By Dunc in forum Engine & Drivetrain
    Last Post: 17th August 2008, 11:54
