Results 1 to 10 of 15
Thread: tuning box problems
    May 2008
    northern ireland
    Default tuning box problems
    need bit of advice. i just had new fuel pump fitted in vectra sri 120 with 30k on clock.but for last five months was running dtuk green box in car at 12oclock setting, so was wanting 2know did tunning box stuff up fuel pump.i am having second thoughts bout putting box back on car as car out of warrinty next month.
    thanks for any replys william..
    Full Member Big Sig's Avatar
    It can do yes. They fool the ecu into upping the fuel pressure and boost pressure to give you more power.
    [Ex]Admin Duncan's Avatar
    Not boost pressure, simply fuel pressure.
    As Big Sig said though, any tuning box simply due to the way they work (fooling the engine and not working in harmony like a remap) can cause issues, or bring to bear much quicker any fragile/iffy components.
    Sorry D, i was under the impression that along with the higher fuel pressure the ecu upped the boost pressure also?
    Regular Member jonesy_ni's Avatar
    Co Antrim
    I think if u drive it like u stole it most of the time then yes.
    Normal driving and enjoying the extra power every so often should be pretty ok?
    Nah, not with a tuning box, they simply can't do that. All they do is simply fool the ECU into upping the fuel pressure. More intelligent boxes like the Spider etc. can vary how much extra fuel they cause to be put in at different revs etc. but it can't alter the boost. That basically requires different software settings in the ECU i.e. a remap.
    Full Member Jay Kay 313's Avatar
    Burgess Hill
    If I was going to tune the engine I would only go down the remap route Im not keen on tuning box's. Ok it is more dosh but more controlable though the system to the site btw
    Astra Estate SRi XP 1.7 CDTi 100
    Sunny Dartmoor
    Tyneside
    Quote Originally Posted by jonesy_ni View Post
    Don't see the point in having the extra power then. If you can only use it every now and again it's going to waste.
    Get a remap mate as tuning boxes are the cause of problems IMO.
    Regular Member mikey68's Avatar
    May 2008
    aberdeen
    A remap is the best way to go but I have been running SRI CDTi 150's over the last two and a half years. I have used the tuning box on car 1 for 30k miles, car 2 for 32k miles and no problems on either. Just picked up replacement car yesterday, another black cdti150, but this will be remapped I think, just to compare. I was running tuning box and a cr eco2 green. Green box slower than my other one. Nowhere near as much pull in 5th and 6th.
    Normal driving with the odd blast about won't cause problems with tuning box. Had a tuning box on 2 passat tdi's before these and did approx 100k miles in total without problems. PS I drive like a cnut!! :-)
  1. Spider Tuning Box Problems?
    By SteveBray in forum General Motoring Chat
    Last Post: 9th December 2011, 15:18
  2. radio tuning problems, help anyone.
    By melvyn8181 in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2011, 21:26
  3. Problems fitting a tuning box to the 120.
    By felixx in forum Engine & Drivetrain
    Last Post: 19th July 2010, 21:05
  4. Caterman/T-Tuning Tuning Box for 1.9CDTi 150 (Z19DTH)
    By CHRISRi in forum Parts for sale
    Last Post: 25th May 2009, 18:49
  5. CR1 Tuning Box Problems HELP!!
    By cameraman in forum Diesel Engine related
    Last Post: 30th October 2006, 11:42
