Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Wheel Bearing
    Regular Member suj786's Avatar
    glasgow
    Unhappy Wheel Bearing
    Finally got the car checked out regarding Rumbling noise under the bonnet.
    Technician took it for a quick test drive, during which time I bombarded him with veccy questions (turned out to be a pretty one sided conversation)
    He figured it wasn't timing belt but the wheel bearings. So I thought thats a good thing, wheel bearings can't be more expensive than a timing belt.
    £221 FITTED
    and thats just for ONE.
    So the car's booked in for monday, thought I'd get squeeky alternator belt changed too at the same time (£30 fitted)
    now, I know roughly what a wheel bearing is, but how does it wear our/get damaged ???
    Jan 2006
    Dalriada
    £221 for a wheel bearing????!!!!
    pretty steep that.
    What garage mate??
    glasgow
    Arnold Clark, Glasgow.
    Although I do get a 10% disc, but its still alot of money. They quoted £128 for the part
    Regular Member denzo's Avatar
    Runcorn
    Suj
    I would go to an independent garange ... should cost no more than about £100 fitted.
    Wheel bearing used to be a metal ring filled with steel ball (bearings) coated in lots of grease
    glasgow
    I've got a habit of buying OEM parts.
    Does any third party make these and are they just as good.
    I think its a bit steep too. But dont know where to go from here ?
    Mileage : 000
    If the bearings[ I belive they are rollers as to balls] wear then there becomes "play", that, if you like allows the rollers, to "rattle" about rather than to run true in the inner and outer races.thus making the rumbleing noise.
    It sounds a lot of money to change the bearing though.
    Jan 2006
    Dalriada
    suj you will probably find the bearings from an independant garage are the same as the ones being fitted by vaux at 2/3/4 times the price.
    which arnold clark so as i know to avoid it as thats way tooooo much for bearings to be fitted.
    glasgow
    Quote Originally Posted by gil16e
    Pollokshaws road, Glasgow
    they are normally ok
    Jan 2006
    Dalriada
    call another vaux garage and see if the price is the same cause your 10% discount card works in all the arnold clarks.
    If you want a number of phoenix give me a shout
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Don't think that the bearings are of the old press out sort,think you have to have the whole hub assembly
  1. UJ or wheel bearing?
    By Endricks in forum Engine & Drivetrain
    Last Post: 8th April 2012, 10:49
  2. Wheel Bearing ?
    By jer75 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2011, 02:01
  3. wheel bearing
    By stuart bigboy in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2007, 17:07
  4. Wheel Bearing with VX?
    Last Post: 6th March 2007, 00:19
