Results 1 to 10 of 27
Thread: Rear issue
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Rear issue
    I have noticed a couple of times when turning into my road at home that there is a slight clunk from the back end. I assumed it was something the boot / spare wheel are moving.
    However, last night it did it and i thought I would investigate a little.
    I grasped the O/S rear road wheel from the side at the top and shook inwards and outwards. There was slight movement and a slight clunk, like the wheel was a bit loose. I checked the wheel bolts and they were all tight. Any ideas to what it could be?
    The near side did it very, very slightly too (but it could have been the offside actually doing it, and the noise transmitting through the rear suspension)
    TIA
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    How old is the car ?
    play in the wheel combined with a knocking noise usually means worn suspension bushes.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    04 with 85K.
    Looking for some guidance to where I should focus my effort
    85k miles is more than enough for worn suspension bushes
    If you've got a trolley jack, or axel stands, get the car up and get on your back and have a look. Get somebody to wiggle the wheel for you.
    If you can get a torch or something down there, you should see the suspension bushes moving about. The knocking noise is the 2 pieces of metal meeting, that would normally have a bush between them.
    Birmingham
    Sounds like the dreaded upper suspension arms.....have a read of this thread, ive got the same issue and am changing mine this weekend, come rain sleet or snow!!!! Oh, and the ARB bushes! HTH..
    THis thread is headed ARB bushes, and is quite a long thread, but read it all and it will become apparent....I did the same test, grabbed the wheel from the top inside and pulled towards me and had a clunk....gave it away.
    A BIG THANKS TO: merikiito who told me about the test.
    THREAD: http://www.vectra-c.com/forum/showthread.php?t=50690
    Have a read before you go spending loads of money on the wrong thing!!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    sounds like a bush to me...
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is there a how to for the arm?
    Feb 2007
    Glasgow
    Birmingham
    Quote Originally Posted by Ste View Post
    Did you have a read of that thread? Sounds to be a common problem.
    Bye bye Vec B
    - Hello Siggy!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Read the thread (bit long and boring) and it mentions the how to, but doesn't point to it.
  1. Rear Screen demister issue
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2013, 08:54
  2. Rear wiper jet issue
    By fattony in forum Bodywork & Interior
    Last Post: 1st August 2011, 08:21
  3. Rear Screen Washer Issue
    By Kev_G in forum Bodywork & Interior
    Last Post: 21st March 2011, 00:39
  4. Help! - Rear bulb holder issue
    By benwalters82 in forum Bodywork & Interior
    Last Post: 29th May 2010, 20:53
  5. Rear Tyre Issue?
    By rsocon in forum Suspension, Wheels & Brakes
    Last Post: 3rd March 2010, 09:20
