Thread: 1.9cdti sri flywheel
    Regular Member PAULMAC77's Avatar
    warrington
    Default 1.9cdti sri flywheel
    i have just bought a vectra 1.9cdti sri 150 and since picking it up yesterday i have noticed a noise that goes when the clutch is depressed in. Now from reading all the storys on here i assume this is the dual mass flywheel, what my question is, is how long do they usually last before they fail? it changes gear fine and the clutch is bahaving normally, just this noise sometimes not all the time but when its there it goes when u press the clutch
    Swinton, Mexborough
    I had the same problem. my car has covered 100k. there very expensive plus youll need a clutch kit as well my as well do both while the cars in bits. ended costing me about £800. had to buy parts from vauxhall and local garage fitted them for me.
    Birmingham
    No specific duration or miles....I had one of mine done at less than 10k!!! Is yours still under warranty???
    Can someone advise if this is a recall or only a warranty or ££££ job?
    Bye bye Vec B
    - Hello Siggy!
    warrington
    no no warranty i just bought it privately its and 04 plate with 71k on it.
    South east
    A noise that disappears when you press the clutch can also be caused by gearbox bearings.
    londonderry
    Quote Originally Posted by Rebellion View Post
    more chance of clutch release bearing don't go scaring ppl into thinking they need gearbox's lol
    use your internet guys ffs! clutch an flywheels z19dth sachs/LUK should cost no more than £400-£500 depending who you know an £150 labour
    warrington
    do these have clutch release bearings, i thought maybe it mte have one of those concentric slave cylinders in it?? i know more about volvo's than vauxhalls with me working there
    Apr 2008
    SHeffield
    My signum has just been in for the same problem, it has done 55k. Dealer told me it was the DMF. They fitted a new one, no questions asked all under warrenty. I took it back in this morning because the noise is louder than ever. Turns out it is a gear box, I am waiting for vauxhall to authorise the dealer to fit a new one under warrenty.
    dudley
    Hi all
    I have found out that the flywheel is a 'Sachs' design and as such has planetary gears between the masses. I think this differs from the LUK types.
    If anyone can elaborate that would be welcome.
    cs
  1. 1.9cdti clutch and flywheel change
    By danny_n in forum Engine & Drivetrain
    Last Post: 13th July 2011, 21:57
  2. 1.9CDTI 150 clutch / flywheel issue
    By LGD in forum Engine & Drivetrain
    Last Post: 28th January 2011, 00:29
  3. 2004 150bhp 1.9cdti flywheel question
    By veccyjoe in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2010, 21:59
  4. 1.9CDTI 120 Dual Mass Flywheel...
    By danBoy in forum Parts for sale
    Last Post: 6th August 2009, 20:37
