Results 1 to 3 of 3
Thread: egr valve
    Regular Member nufckev's Avatar
    May 2008
    NEWCASTLE
    Default egr valve
    Where is the egr valve located on the 52 vectra 2 dti and what is the best way to clean it
    it's under the black plastic engine cover.. remove that, the top air intake hose as well.. then you can remove the 4 bolts that hold the top part of the manifold on..that will reveal the part of the manifold that lets the EGR gases back into the engine... there are 2 water lines and 1 electrical plug to undo on the block below it.. that block is the EGR valve..2 bolts secure it.. undo the bolts, wriggle the EGR out and it's off... i use carb cleaner to decoke them, along with a small softish brush..
    Glasgow
    Default Emissions light
    I had the emission light on about two months back and had it diagnosed as egr valve...duly replaced and problem solved..untill today. I will be going back into the garage to have it checked but could it be anything else ?
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
