Thread: Oh No....Water Leaking into Boot!
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Default Oh No....Water Leaking into Boot!
    As titled, opened the boot the other day to find the boot carpet soaking wet, but only in one spot. My guess is its coming through the rubber seal on the frame, but I can't see any fault with it
    I'll do a water test with a hose when I clean the car later this week, but does any one know/experianced ware & tear on this rubber and if so how much a replacement would be?
    Thanks in advance!
    spoons
    Guest
    Quote Originally Posted by chrisschild View Post
    Do you have a trunk monkey ?
    Birmingham
    I used to have a similar problem on a Vectra-B, the R-reg type ones, it was my rubber that was knackered and I managed to get one from a scrapyard for a fiver, did the trick.
    Im thinking your problem was similar and if so, rubbers for the Vectra-C should be easily available from a local scrappy now?
    Mine had 2 splits in it, one where the tailgate met with the rear light area, and one near to the roof line.
    HTH.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I think Andy Loom had problems with his boot aperture seal resulting in a wet boot carpet.
    I had water leaking in the boot via the ariel mount but that bypassed the carpet and just collected in the spare wheel well so maybe not the same as yours.
    HTH
    Surrey
    It could also come through the rear lights.
    i had it running in via the holes under the SRi rear spoiler .. VX hadn't sealed it properly..
    All i can reccomend chris, is that you remove all the boot trim and run a hosepipe over the car.. that'll tell you where the water is coming in..
    Nicking Ya Dinner.
    Quick, get your speedos out, you just became the proud owner of a Jaccuzi spec'd Vec.
    p.s Chris you might wanna check this out for some DVD backing track
    http://www.youtube.com/watch?v=cpR_UPYanAc
    East Midlands
    Thanks in advance!
    Have a look at this thread might help ya http://forum.vectra-c.com/showthread...ng+boot&page=3 Good Luck.
  1. STILL leaking water! I'm going to scream!
    By DNS in forum Bodywork & Interior
    Last Post: 7th March 2014, 00:28
  2. o2 Router leaking water
    By bigmac in forum General Chat
    Last Post: 30th October 2012, 16:34
  3. water leaking
    By jinkie in forum Engine & Drivetrain
    Last Post: 14th August 2012, 19:51
  4. Water leaking in car fix -* VIDEO *-
    By shammon in forum Bodywork & Interior
    Last Post: 28th April 2012, 19:47
  5. Leaking water
    By peter142 in forum Engine & Drivetrain
    Last Post: 5th September 2007, 15:10
