Thread: 1.9 cdti rattle
    Swinton, Mexborough
    Smile
    Hey guys iam new here so hello ,
    Got a vectra 1.9 cdti sri. got 100k on the clock. getting cam belt done soon. when i start the engine its fine for about 5 seconds then the engine starts to rattle. cant put my finger on what it is any ideas?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Loose heatsheild? Cat breaking up?
    Birmingham
    Have you tried the black engine cover? Could be loose bolts if its the 120 CDTI or worn rubbers on either?? Just a thought, hope its soemthing cheap and simple. HTH.
    Bye bye Vec B
    - Hello Siggy!
    Swinton, Mexborough
    Ill check the engine cover but the rattle goes away after the car is warm. Any more ideas?
    Regular Member Gaz the Cab's Avatar
    Nov 2007
    Chester
    Dual Mass Flywheel????
    Swinton, Mexborough
    just had a new fly wheel and clutch fitted about 5k miles ago. i think it meant be the cat. the rattle comes from the back of the engine when laid on floor and rev engine with hand can hear something rattle going to get it checked out. let you know
    Regular Member mikey68's Avatar
    May 2008
    aberdeen
    Interesting. My mate has the astra 1.9cdti and he has this rattle we couldn't find the source of. The car has been stripped by VX and also had bits changed. VX basically fobbed him off in the end saying it was just a characteristic of these engines. Mine doesnt do it.! He had parts fitted from another car, noise went away. Parts put back on and no rattle then it started a while after. It's intermittent now but car is off on a transporter for a while to be looked at down south. I'd love to find out what it was. The noise started after it came back from a service and sounds like a loose idler pulley rattling on the offside engine side, from under wheel arch is more obvious. Worse when warm!!
    noise from the offside???... timing belt cover area?.. i wonder if it's the waterpump on it's way south??...
    May 2008
    aberdeen
    None of the usual suspects which I could think of. I could only imagine it was a bearing or pulley related thing as nothing was loose where we checked. VX specialist has now said nothing wrong with it. My mate is wanting to return the car. Car goes well apart from the noise.!!!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    cam belt tensioner, get the belt changed asap as mine went and took the engine out! But its just a guess but mine caused a rattle
  1. 1.9 CDTI (150) Strange Rattle
    By DuncanM2009 in forum Engine & Drivetrain
    Last Post: 20th November 2011, 23:04
  2. cdti 150 rattle
    By stickygreen in forum Engine & Drivetrain
    Last Post: 24th July 2011, 07:52
  3. request to all with 1.9 cdti dmf rattle
    By barney490 in forum Engine & Drivetrain
    Last Post: 20th February 2011, 16:33
  4. cdti 150 rattle?
    By ryanhamil in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 02:24
  5. 1.9 CDTi engine rattle
    By Jay Kay 313 in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2007, 19:25
vauxhall vectra 1.9 cdti engine rattle
what could be the rattling noise comeing from the timeing cover on my vauxhall vectra 1.9 cdti
1.9cdti noise after timing belt
vectra c 1.9cdti pulley rattling
vectra 1.9 rattle from cambelt
vectra rattle on pulley tensioner
vectra c drive belt tensioner rattling
vectra c alternator tensioner rattle
astra 1.9 cdti rattle
cdti rattle when revving
astra 1.9cdti 150 cambelt tensioner noise
astra 1.9cdti 150 tensioner noise
vectra c cdti alternator tensioner engine noise
vectra cdti pre cat rattle
vecta c 1.9cdti cambelt noise
