Results 1 to 10 of 24
Thread: Which diesel to buy? 1.9 or 3.0V6
    Apr 2008
    Kilmarnock
    Default Which diesel to buy? 1.9 or 3.0V6
    I currently have a Vectra B 2.5 V6 CDX Estate Auto. I am starting a new job and I have the option of car allownace. With the car allowance comes a fuel card. The criteria is that the car I buy must be under 3 years old, seat 4 passengers in comfort and return 35+ mpg on the combined figure.
    I have been looking at buying a 55 plate onwards, facelift Vec-C hatch Elite. I just dont know whether or not to go for the CDTi 150 or the 3.0 CDTi V6. I know there will be a road tax issue but I am not bothered by this.
    So, points for discussion :
    1. I am keen for views on performance, reliability, common faults etc.
    2. I have never had a diesel before but I am aware of seeing piles of smoke coming from diesel cars under acceleration. Surely this is not normal...is it?
    3. Has anyone done a head to head between the two?
    4. How are they for tuning?
    Kenny
    Nicking Ya Dinner.
    3.0 CDTi
    Speed - not a lot in it
    MPG - 5mpg difference on the motorway
    Reliable - V6 every time
    Spec - Most V6's come in the better specs - I recommend an Elite
    1.9 is tunable - 3.0 is but isn't recommended
    right.. unbiased opinion coming....
    the 3 ltr is far more reliable as an engine that the 1.9's.. they 1.9's suffer from amongst other things, turbo failure, swirl valve actuator failure, injector seal leakage.. the 3ltrs suffer far less with faults
    the 3 ltr isn't as quick off the mark as a 1.9 as it's a heavy engine, but there is very little between them.. the 3 ltr makes 180BHP , the 1.9 will make 120 or 150 depending on it i's the 8V or 16V model
    the smoke is either because they need servicing or because someone has stuck a tuning box on and are busy dumping loads of excess diesel into the engine which isn't getting burnt.. It shouldn't smoke...and the police will stop you and order you off the road if it is excessively smoking..
    i don't think anyone has done a head to head.. but i have owned a 150 1.9 CDTi and have extensively driven a 3 ltr, so i think i can give you a fair comment..
    Tuning?.. basically if it's a 3 ltr then Don't... the high pressure fuelpump just doesn't like it and if it goes pop it'll be around £3.5K
    the 1.9's have loads of tuning option ranging from remaps down to a £65 tuning box...all will see similar fugures...but beware.. the 1.9 is best described as a fragile engine..they fail when in standard form, let alone when tuned.. my advice is if you are considering a 1.9 then get a fully comprehensive warranty that will cover you if it does fail..Ours had 4 turbo's in 26K miles...
    If you need a quick, reliable, car.. buy the 2.0ltr petrol..if it has to be an oiler, get the 3 ltr and it should do the magical 35mpg combined..
    Tyneside
    2.0T gets 35mpg on a run when driven accordangly, maybe 40 if you put the granny slippers on, doesn't smoke, is very reliable and doesn't sound like a tractor Oh and is very tunable However I would say the 3.0 V6.
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    if the car tax thing is not an issue then the 3.0 v6 cdti everytime
    but then again i am biased
    South east
    .... if you're not used to diesel - and therefore the extra NVH (noise/vibration/harshness) - then the V6 will be less of a culture shock for you.
    Oct 2007
    Back in Belfast!!!!
    Quote Originally Posted by Rebellion View Post
    infact i would go as far to saying it does not sound like a diesel at all,and the ride is really smooth
    Jan 2006
    Hornchurch
    when i had my 1.9cdti it was at the dealers more then my house engine probs a 1.9cdti Elite faceliift Estate Auto
    Good car crap engine the 1.9cdti must be made of chocolate
    the 3.0v6cdti I had a drive in for a bit was very nice i would go for the 6 speed man box in the car if poss
    Full Member Big Sig's Avatar
    Get the 2.0t or the 3ltr diesel. The 3ltr isn't affected by the tax much, mine is £210 this year, £260 next and £270 on 2010 as it is at the moment. The turbo lag on the 1.9 was one of the reason's I didn't go for it
    Apr 2008
    Kilmarnock
    Thanks guys for all your replies. I will have a look at the 2.0T, but it certainly looks like the 3.0 V6 CDTi is top of the tree at the moment.
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. V POWER DIESEL Vs DIESEL
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 21:22
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
  5. 2.0 Diesel
    By cp123 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2006, 23:50
