Results 1 to 10 of 25
Thread: Any Dj's????????
    Regular Member coylo5's Avatar
    May 2007
    n.ireland
    Default Any Dj's????????
    have we any dj's on here, im tryin to record music from a set of decks to my laptop im currently using a twin rca to mini jack lead but on playback it has a very muffled sound to it. just wondered if im even doing it right
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    I do a bit of mixing from time to time. I have leads from my decks going into the pc, cable going from two into one connection, into the audio imput on my pc. Just make sure it's not too loud, use the setting on the mixer to get a good audio going into the pc. On my audio setting on the pc I have a bar for the volume, just keep it off the red and you should be fine
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Dont Decks need pre amps, hence why they have specific input terminals on amps.
    Feb 2006
    North East Uk
    On my cd decks I have a record out on my mixer to go into any device, thats the lead I have into the pc. I have cd decks, amp and mixer all hooked up. Then the lead to record my sets going into the pc
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    I can do a bit of scratching
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by ian_c View Post
    There actually used to be a great DJ called Ian C, early 90's stuff.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    You need one of these (or similar)
    http://www.maplin.co.uk/Module.aspx?...reamp&doy=23m6
    Feb 2006
    North East Uk
    I never needed nothing like that for my set up. It all probably depend on what kind of sound card you have.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    It actually depends on the deck not the sound card. If the deck is a household one then it will almost definitely need a pre-amp. If it's a pro DJ one then it may not.
    May 2007
    n.ireland
    Quote Originally Posted by Mark2.2 View Post
    so keep the volume low on the mixer
    what software do you use?
