Results 1 to 10 of 11
Thread: Dificult to start after service?
    Aug 2007
    Varazdin,Croatia
    Default Dificult to start after service?
    Sory for my bad English.After a big service my Veci 2003. 3,2 v6 is dificult to start.I changed sparks,all filters all belts and cleaned injectors.Now i am sory for doing this because before car worked perfectly.It is not showing errors.Help please what could it be.its driving fine but start is sometimes dificult it turns 5-6 times before starting.Thank you
    did you change the cambelt??
    the airfilter/fuel filter will not make much difference to how it starts ( providing you fitted the fuel filter the right way round with the 'flow' arrow pointing towards the engine..
    if the spark packs are pushed firmly down onto the plugs and the multiplugs are firmly connected to the sparkpacks then it should be firing up fine..
    if it's not showing fault codes, my thoughts lead towards fuel...
    when it does run, does it run smoothly?...does it idle?..
    when you replaced the plenubm did you make sure there was no air leaks and that the oring seala were in good condition?
    Aug 2007
    Varazdin,Croatia
    When it starts it work fine and going like hell.I changed cambelt.The fuel filter didint have an arrow on it and i placed it like the old one.
    the fuel filter should have an arrow on the body of it.....
    i think it may be an airleak weakening the mixture, if you are 100% sure that it's timed correctly..
    Aug 2007
    Varazdin,Croatia
    It s timed correctly.
    how did you clean the injectors???
    Aug 2007
    Varazdin,Croatia
    In ultrasonic tab i thing this is the name.I read in Autodata it can be a connector(sensor) for coolant it turns choke on or somthing like this.
    yep, the fuel enritchment is a function of the coolant temperature sensor..
    if the injectors were ultrasonically cleaned then did they have a spray pattern check afterwards to see if they are fuelling correctly..?
    i think it's got to come apart again to check that you have reconnected everything that came off correctly..
    Aug 2007
    Varazdin,Croatia
    It tok me two days after work to do this and now again.Could it be that connector or not?
    it could be so many things.... you'll just have to work back and check what has been done to see that it is all correct....
  1. Service book - copy of service page (2.0 DTi)?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 22:48
  2. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  3. Free MOT & Service reminder service
    By norfolk in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 05:59
  4. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
