Results 1 to 10 of 13
Thread: Rear Camber
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Default Rear Camber
    Well just got back from wheel alignment centre and they cant do it Saying they cant get a measurement from the wheel hub centre to the arch
    South east
    What wheels have you got on there?
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Daywalker View Post
    Huh?! I had mine done on a Hunter unit earlier this year and no problems with measuring from the hub centre to the wheel arch - even being lowered 30mm on 18s. Why exactly couldn't they measure that?
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    I got TSW 5 spokes
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    They said because its so low -45mm that the machine couldnt get a reading between the wheel centre and arch, im as confused as you are. I got a feeling they didnt want to do it.
    Hmm, -45mm is rather low and maybe out of scope/range for the machine? Obviously they can still physically measure the hub centre to arch distance no matter how much it's lowered, but it could be that measurement is out of range of their equipment/software? Maybe worth clarifying?
    Was it a place using Hunter equipment or something else?
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Could have been that duncan out of range for the machine. Its a place with hunter, GSi 3.2 told me to go there
    Given your postcode I'm assuming it was F1 Tyres? (where I went). I can only assume you were out of range for their gear with a 45mm drop?
    I did see you there Alan.. i did wonder if you were getting it done..
    they did mine fine at -30mm... i'll drop in tomm and have a chat to see what they are on about..
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Ok mark otherwise im going to get some eibachs
  1. Rear camber
    By johnnyboy1985 in forum Suspension, Wheels & Brakes
    Last Post: 14th August 2011, 07:10
  2. Rear camber
    By Fig-sri in forum Handling & Braking
    Last Post: 26th February 2011, 15:05
  3. rear camber
    By tditony in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2009, 18:37
  4. Rear camber
    By WHOOSH05 in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2008, 21:39
  5. rear camber
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2008, 20:37
