Results 1 to 10 of 13
Thread: Rear Suspension bolts
    Regular Member phil67's Avatar
    Nottinghamshire
    StatsVehicle Info
    Default Rear Suspension bolts
    Just had a quick look as i need to change my leaky rear suspension and it appears not to be a standard looking bolt. More like a spline thing
    Any ideas? And would halfords stock them as im also thinking about buying the 150 piece set, even better would one be in the kit.
    StatsVehicle Info
    You need an E20 socket and an 18 m/m spanner Phil. You might have a bit of a job getting the E20 socket though. Might need to look on the internet. Or if you have a very good tool stockest near you he might be able to help.
    Nottinghamshire
    StatsVehicle Info
    I take it an E socket is different to a standard one any idea of cost?
    They dont want to make anything simple nowadays, its just a way to get you in to a garage
    Sunny Dartmoor
    StatsVehicle Info
    Quote Originally Posted by phil67 View Post
    You can say that again phil,good luck sourcing the tools m8.....
    StatsVehicle Info
    you'll need E20 and E18.. both of which will come in the halfords 'pro' range of tools 'monster' set... they also sell them seperatly..
    they are TORX sockets, and it's worthwhile buying a set as the vectra is put together with an awful lot of TORX fittings
    Nottinghamshire
    StatsVehicle Info
    Thanks Mark
    Birmingham
    StatsVehicle Info
    Looking for the same socket....am I right in saying its the E20 Female Torx Socket? Went to my local car stockist - Fletchers - and they didnt know what it was, until I had to draw it....!
    Bye bye Vec B
    - Hello Siggy!
    South east
    StatsVehicle Info
    Birmingham
    StatsVehicle Info
    Going to pick this up tomorrow: http://www.toolmanyardley.co.uk/prod...?productid=266
    http://www.toolmanyardley.co.uk/file...-image-266.jpg
    Should do the trick shouldnt it?
    Goes from E4 to E24 with a 1/2" drive!
    Any good?
    Bye bye Vec B
    - Hello Siggy!
    StatsVehicle Info
    that'll cover all you'll need..
  1. Irmscher Rear Wing Bolts
    By Bethan39 in forum Styling
    Last Post: 7th October 2011, 19:37
  2. Rear Camber Bolts
    By spoons in forum Parts for sale
    Last Post: 28th February 2011, 13:24
  3. Nightmare trying to remove the rear caliper carrier bolts!!
    By richiem in forum Suspension, Wheels & Brakes
    Last Post: 4th February 2011, 01:10
how to change rear springs on a vectra c
https:www.vectra-c.comforumshowthread.php51318-Rear-Suspension-bolts
