Thread: Manual Gear Linkage ?
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Question Manual Gear Linkage ?
    Can someone tell me how to set the gear linkage cables - but gear lever end?
    I see they both clip into the remote, but is there an easy way to set them up?
    1.8 5 spd manual petrol btw
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If it's a f23 box put it in neutral then lift up the gaiter and right at the bottom you'll see the cables,these go into two oblong plastic clips, lift the release clips and then on the rear of the gearstick pivot is an oversize staple,this has to be pushed into two holes on the gearstick,which will then lock the gearstick in neutral then you do up the cable clamps,put the gaiter back and the job's done,the holes are just visible on the upper gearstick shown in the second photo.http://www.vectra-c.com/forum/showthread.php?t=21318
    May 2008
    Bucks
    Cheers m8
    I had a go n seem to have sorted all the gears.
    Mind you its now a 6spd linkage n knob but with a 5spd box, but they all seem there lol
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Glad to help,Knowing VX the gearstick assembly 5 or 6 speed would fit most VX's except the auto's!
  1. Corsa-C Gear Linkage
    By LJ sxi-nav in forum The 'Off Topic' room
    Last Post: 8th June 2010, 14:39
  2. Gear linkage knackerd
    By stitchi1973 in forum Suspension, Wheels & Brakes
    Last Post: 29th October 2009, 14:32
  3. Gear linkage cables
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2006, 15:19
