Thread: Will this be covered under warranty ?
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    Default Will this be covered under warranty ?
    This may seem like a stupid question but is this covered under warranty?
    Sorry double post please delete 1 admin
    Regular Member simac's Avatar
    Wirral
    ohh I don't know, could be worth a shot but they might try saying that there is damage allowing water in from impact etc etc
    A lot of Vec lights have gone like that, i've got dead flies in mine too ! LOL
    Birmingham
    Worth a shot I would think!!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member SXi 2.0t's Avatar
    Helsby
    I would think you might have a chance if its inside lens, but if its just on the outside of sealer then possible reject it. That was how it worked when I worked in a Honda Dealership uptill leaving earlier this year.
    Wirral
    Just thinking, how old is the car ? and is that classed as a body fitting which isn't covered after the first 12 months I had a fight with them along these lines when I got the "chrome" window strips changed.
    May 2007
    Sheffield
    Quote Originally Posted by simac View Post
    56 Plate m8y
    [Ex]Admin Duncan's Avatar
    If the car is older then year then no it won't be covered as that will be classed as a body fitting so only covered for the first 12 months.
    No harm in giving it a shot, you never know - but expect them to say no.
    May 2007
    Sheffield
    ok chaps thanks for replies
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    There are a few threads about mouldy rear lights and mine are the same.
    I don't think water enters the light cluster itself so shouldn't cause any problems, its just a bit of a water trap causing mildew to form.
    I doubt warranty would cover it, they might just try using a jet washer on it. Someone on here took his lights out and put clear Silicone round the seam which sorted it.
  1. is battery covered by warranty ?
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 17:02
  2. Is it covered on warranty?
    By adamtaylor in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2009, 18:18
  3. network q warranty covered/not covered
    By johnturbo in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2009, 15:34
  4. is clutch covered by warranty ?
    Last Post: 30th May 2009, 22:38
  5. Is the Air con compressor covered by VX warranty?
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2006, 19:11
