Thread: Fault code 55 (Faulty ECU?). what to do?
    May 2008
    Hertfordshire
    Default Fault code 55 (Faulty ECU?). what to do?
    Hi,
    my car is a vectra 1998 2.5 v6 CD. just few weeks ago the engine warning light started to go on. i did the paperclip test and found the fault code is 55. if i've interpreted the fault code correctly then it's a faulty ECU. can anyone pls tell me where to go to fix this? as far as i know it's a dealer job. but i really dont wanna go to any dealer as they gonna rip me off. pls help...
    thanks a lot.
    Quote Originally Posted by sudiptabd2002 View Post
    er, that's a Vectra B
    Presumably you are receiving
    *****_*****
    *****_*****
    *****_*****
    and that only
    If so, then you do indeed need a new ECU
    Sadly, that is a dealer only job and you are looking at near on £1000 including parts and labour
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    ouch!....
    The simtronic ECU is about £650, it is located behind the glovebox
    It then needs fitting and reprogramming
    The main problem is not the amount of labour involved, removing the glovebox and faulty ECU, refitting the replacement ECU and glovebox, is only about 2 hours, but the car then has to sit in a bay connected on TECH 2 for about 4 hours
    Apr 2008
    Turkish Republic
    Default TCM
    You've told about the price of ECU. Do you have any idea about TCM. How much is ti?
  1. Fault code po403 exhaust gas recirculation valve.faulty.
    By Dobs in forum Engine & Drivetrain
    Last Post: 8th September 2012, 13:37
  2. Help with fault code,
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 21:57
  3. Mini LCD Fault Display is faulty (in RPM gauge)
    By RMillerin in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2009, 22:04
  4. fault code help
    By tankman in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2008, 11:07
  5. Fault code ID
    By Jamesdti in forum Engine & Drivetrain
    Last Post: 21st March 2008, 04:24
opel ecu code 55 replace ecu
