Thread: Key Fob Battery Change
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    Default Key Fob Battery Change
    how the hell do open the key fob to change battery
    its the 3 button one
    driving me nuts ive made a rite mess at the back of fob.
    Jul 2006
    Take it to somewhere like Hellfrauds? Even a main dealer? It must be a 2 minute job for someone who knows what they're doing.
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    on the back is a slot .put a blade in there and twist.. the key part will slide of the fob. you then open the fob in to 2 bits.
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Volvo V50
    Trim : SE Lux
    Engine : 1.6 Drive
    Year : 2011
    that will get the blade off..
    what you don't know is there is a time limit on how long you can do the job for before the key will need resync ing to the car..
    you need to replace the battery in under 30 seconds.. so, take the new one out of the packet BEFORE you start....
    located the blade release slot on the back of the key, insert a thin screwdriver and twist, the blade will slide forwards and off.. you will now see a red seal running around the middle of the keyfob.. seperate the keyfob along that sealline.. the battery will now be exposed.. very carefully ( and quickly) so that you don't break the retaining legs, flick up the old battery and shake it out and slot in the new battery.. panic is now over..
    reassemble the key and try the remote on the car.. it will work fine if you were quick enough.. if not the procedure to resync it is in the handbook that came with the car..
    Regular Member corman's Avatar
    Mar 2007
    hexham
    forget 30 secs, took marks advice and had the new battery ready, literally it was just a split second, well maybe 2 secs maximum, went out to test it and it didnt work!
    tried it even quicker with the second key and still didnt work!!!!!!!!!
    luckily it was just a case of putting the key in the ignition to re-synch them
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    as mark say change it within 30sec i'm talking from experiance here i had to get mine re-programmed altho i have a few mates work in the stealers down it for noet but would have cost £35+vat
    South east
    Quote Originally Posted by parapaul View Post
    lol
    Regular Member Vectra-Dog's Avatar
    Birmingham
    I have to re-sinc my key every now and then, It just decides it doesn't want to unlock the doors.
    Slot it in the ignition and it's done.
    Have changed the battery and it still does it, Inconvenient sometimes but not realy a problem.
    Regular Member SignumPhil's Avatar
    Luton, Beds
    if you keep it in a pocket and it gets pressed by accident a few times it can go out of sync with the car.
    Phil
  1. Battery Flat after thermo change?
    By unknownbullet in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 18:00
  2. outside temperature display's "F" on the display after battery change
    By Philhammond2004 in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2012, 19:12
  3. Key Fob - Battery Change
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2010, 22:10
  4. Fob battery change
    By Gazza36 in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2010, 18:56
  5. Key Fob Battery Change?
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 16:22
vectra c key fob battery
vectra c key fob battery change
vectra C remote key battery warning
vectra c remote battery
vectra c replace key batteryvectra c key fob open2007 vectra c ignition remote battreyreprogramming key fob after battery replacement vectra c vauxhall vectra c key fob battery sizehow to change battery in vectra c keyvectra key fob battery 2004replacing battery in signum key fobPIC OF VECTRA C CAR KEYvauxhall vectra key fob battery replacementBattery in my vauxhall key fob doesnt last longchanging thekeyfob battery on a vauxhall vectra c 2006vectra c keyfob batteryvauxhall vectra key fob batteryvauxhall vectra key fob battery changechanging battery vectra c key fobopel vectra c key batteryvectra c remote key fobvectra 2003 key batteryvectra key fob batteryfob battery
