Results 1 to 2 of 2
Thread: Third brake light
    Regular Member chrisdownes's Avatar
    West Midlands
    Default Third brake light
    Ok for my first technical post....
    My third (LED) rear brake light does not work and makes the computer thingymajog say "check third brake light".
    I have tested the LED strip and that works ok, however there is no 12v feed to the connector.
    I have traced the wire back to the multi plug behind the left hand carpet wal in the boot, but there is no 12v supply there either (there is continuity in the wire)
    Does anyone know whether there is a relay or a fuse which controls this third brake light, and if so where abouts it is? I could jumper the wire with another brake light wire to get the third light working, however this wont cancel out the computer message about it not working.
    Help please........
    South east
    Someone once told me my Omega probably had 1 fuse covering all of the lights at the front, so I took a look and found there was a separate fuse for each light function - so 10 fuses just for the front lights. Using that same principle its highly likely you have a fuse just for the 3rd brake light. Look in the fuse box, see if you can decipher which one it is, or if you can only decipher which fuses are for lights but not which lights in particular, then check all of these and you may stumble across a blown one.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Brake light
    By mambo in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2010, 01:36
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
https:www.vectra-c.comforumshowthread.php51120-Third-brake-light
where is vectra 3rd brake light conection
vectra 3rd brake light connection in switchboard
vectra break led light not workibg
vectra c boot brake light wire
vectra diesel boot brake light its not working
opel vectra c 3rd brake light fuse
signum 3d brake light error
3rd brake light vectra c where to buy
vectra c 3rd brake light not working
opel vectra c center brake light fuse
vauxhall vectra third brake light fuse location layout 2008
which fuse controls 3rd brake light on astra
