Does anyone know if its possible to remove the complete handbrake lever assem from within the car - but without disconnecting it from the underside first? From what I gather it can be removed by disconnecting the cable connection underneath the car (by removing a single pin) but is it possible to remove the assem somehow from inside the car? I see the cable end is threaded but cant work out how it might disconnect - if at all?
