Thread: heater problems 2.5v6 vectra
    poole dorset
    Default heater problems 2.5v6 vectra
    just bought my vectra and found the heaters dont work air con is fine,dont over heat no contamination in oil or water the matrix pipes are hot but still blows cold any ideas cheers
    yep, it sounds like a blocked matrix to me... the pipes will heat either side, but with no cross flow it won't actually heat the matrix...
    have you disconnected the matrix pipes and flushed the matrix with a hosepipe.
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    WELLLLLLL???????
    have you?
    poole dorset
    to be honest no ill do that in the morning.but someone said the switch could be fubared is that true
    the heater control switch could be broken yes..but basics first.. does it ( the matrix) get hot to engine temp.
    poole dorset
    i have just put my hands on the matrix pipes goin into the car and they are hot yes
    both sides?.. is there any flow through it?..
    the pipes will equally heat as the are connected to the coolant gallery.. it's flow via the matrix thats important..
  1. heater problems!!!!
    By jammar0 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th January 2012, 23:37
  2. heater problems
    By pete w in forum Bodywork & Interior
    Last Post: 12th December 2010, 21:28
  3. Heater Fan Problems
    By kel123 in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2010, 12:00
  4. Vectra Gsi Heater Problems****HELP****
    By Daz Newell in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2009, 19:24
  5. Heater Problems ???
    By suj786 in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2005, 01:10
