Thread: oxygen sensor
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default oxygen sensor
    hi if i purchase the oxygen sensor is it hard to fit myself
    [Ex]Admin Duncan's Avatar
    What engine?
    Feb 2007
    Glasgow
    From this thread ...
    http://forum.vectra-c.com/showthread.php?t=50956
    Looks like a 1.8.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    What engine?
    its a 1.8 is it hard to replace
    Full Member Big Sig's Avatar
    I think there are a couple, which one do you want to replace?
    as per the other thread... you are best off soaking the sensor thread in wd40 and let it creep in, then using a lambda sensor socket rock the sensor undone back and forth to break up the internal carbon..it should come out that way.. normally when they jam in it's because you've pulled carbon back into the threads as you undo it..
  1. Oxygen sensor removal
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 15:54
  2. Lambda / Oxygen Sensor
    By R-man in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2012, 21:13
  3. oxygen sensor
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 2nd December 2011, 23:25
  4. Oxygen sensor!!!!
    By darrenmac in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 16:53
  5. Help re Oxygen sensor for Z32 SE V6
    By the-converter in forum Engine & Drivetrain
    Last Post: 29th September 2009, 15:31
