Results 1 to 10 of 11
Thread: Steering wheel vibrating side to side
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Steering wheel vibrating side to side
    has anyone had any trouble with a vibrating steering wheel when im on the motorway anything above mph i get a vibrating shake on my steering wheel any ideas what this could be
    Jul 2006
    Quote Originally Posted by pipamish
    anything above mph
    Above how many mph? Is it wheel wobble?
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by parapaul View Post
    above 60 mph
    South east
    The obvious thing to check is whether your wheels are balanced properly. If you can rule that out, then next thing is suspension bushes.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by Rebellion View Post
    me thinks that it will be the bushes as i didnt long have the tracking done would this be expensive
    [Ex]Admin Duncan's Avatar
    Tracking is different to balancing - I'd suspect the balancing first. The Vectra is sensitive to balancing and places often put on too much weight which doesn't help. I'd get the wheels balanced again, asking them to remove all the weights and use minimal weighting for balancing.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    ill get that done cheers
    If your steering wheel is shaking, and can be seen shaking, on a constant speed between 60 and 80mph that is normally due to incorrect balancing on the front wheels
    The solution is have the front wheels rebalanced and ask them to use the fine settings
    This normally resolves the problem
    If your steering wheel is shaking, but can be felt only, on a constant speed between 60 and 80mph that is normally due to a minor incorrect balancing on the front wheels
    Again, the front wheels need rebalanced
    Identifying incorrect balancing on the rear wheels is very difficult
    The only way to do this is to swap the rears on to the front, and repeat the test
    When the wheels are rotated rear to front it is quite common to notice that the need rebalanced
    Personally, as the tyres wear and the rears are swapped to the front I ask them to test them, just to see if rebalancing is required
    If it is then both are done
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    while you are getting the wheels re balanced ask them to check the tyres as one could be slightly out of shape
    Regular Member Craig1985's Avatar
    harwich essex
    what duncan said
  1. steering wheel to one side,while driving straight
    By RRadek in forum Troubleshooting
    Last Post: 3rd September 2011, 10:50
  2. Vibrating steering wheel
    By Matt21385 in forum Troubleshooting
    Last Post: 29th November 2006, 23:43
  3. Replies: 24
    Last Post: 23rd June 2006, 23:24
