Results 1 to 10 of 17
Thread: What next?
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default What next?
    guys i have my 1.9cdti (150bhp) remapped and replaced the airfilter with a k&n one but what else could i do that wouldnt cost the earth to make it go faster thank also have the 314mm brakes to stop it now as well which is good
    Jul 2006
    Exhaust.
    If you've got a DPF get a cat-back system, if you don't have a DPF then get a sports cat too
    Aug 2007
    Lisburn, N.Ireland
    how do i know if it has one or not? how much would i be lookin at for each system with a dual exit? much of a difference?
    Jul 2006
    IIRC it's the automatics, hatchbacks and estates that have DPFs fitted...
    A cat-back system will set you back £350-£400, no massive gains in power but makes a noticeable difference to driveability. If you want a sports cat add an extra £150 or so, but you should get even more noticeable gains.
    HTH
    Aug 2007
    Lisburn, N.Ireland
    is there anyway you can tell by looking? would one of the first in england post to northern ireland or does anyone know anyone here who could do it
    Jul 2006
    I doubt anyone would post one out TBH, they're usually made to fit individually. If you can't find anywhere, you could go halfway and buy an off-the-shelf system but I wouldn't waste my money.
    The only way to tell about DPF by looking is to get under the car and look at the cat... A standard cat has 1 wire in each end (for lambda sensors I think) but a DPF has about half a dozen wires and sensors protruding...
    Edit: Here's one in Co. Antrim... Sounds possible that they may do stainless steel systems...
    Custom Pipes
    50c, Station Rd, Cullybackey, Ballymena, County Antrim BT42 1BU
    Tel: 028 2588 1818
    Tyneside
    You could just de-cat it being a deisel as there is no emissions tests on them, just a smoke test. Again there won't be any big gains, but a worth while mod.
    Jul 2006
    Or from the Powerflow website, they have 3 dealers in NI...
    CARNOISSEUR
    68-71 QUEENS STREET
    BALLYMENA
    CO ANTRIM
    BT42 2BD
    Tel: 02825 637773
    DEE'S EXHAUSTS
    63 MILL RD
    WHITESTONE
    NEWTOWNABBEY
    BT36 7BA
    Tel: 02890 800301
    J.O.N. EXHAUSTS
    6 LOWER CATHERINE STREET
    NEWRY
    BT35 6BE
    Tel: 02830 266622
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    try an fmic
    Aug 2007
    Lisburn, N.Ireland
    a what?
