Thread: Engine oil pressure
    Regular Member luckyluke's Avatar
    May 2008
    S'port and L'pool
    Default Engine oil pressure
    Hello,
    I'm a quite new owner of VC 1.8VVT '57 plate that has done 11k miles. I've got one concern regarding engine oil pressure control indicator.
    When I start the engine after a break (15 minutes and more), this indicator goes out after 2s. When started again, indicator goes out immediately. I recon there is something wrong but I'm not sure if it isn't typical. It only happens once and only after "first" start after short/long brake.
    Any ideas?
    thanks
    it's not too slow, but it's because the oil is draining back..thats what will be causing it..2 seconds isn't too long. the GSi takes longer and thats giving 55psi of oil pressure..
    May 2008
    S'port and L'pool
    Thanks. If I'm to be honest this is the first car (I have had a few) that behaves like this that's why I have this concern. But good to know this is a normal thing. I had some theory about this but I wanted to be assured if I'm right or wrong. Thanks.
    May 2008
    S'port and L'pool
    Just to confirm - what you see in this film http://dagmaralukasz.co.uk/INNE/vc.wmv (first start, indicator takes around 2-3 sec. to go out, every start after indicator goes straight away). Anyone could make similar film and show me... Damn, I know I'm horrible but I prefer to ask twice
    btw - Why I cannot edit my previous post?
    you can't edit it, because the edit time has run out...
    i can take the film.. but i'm not 'techo' enough to list it on here....
    May 2008
    S'port and L'pool
    that's what I thought
    Belive me or not but I am not either . But I managed. And I even pushed myself to use my rubbish English
    So you confirm it's 100 per cent normal?
    i'd not be worried if it took 2 seconds to go out on startup when cold or stood for 15mins or so, but goes out straight away when it's hot/quickly restarted..
    May 2008
    S'port and L'pool
    Just for the record - I checked two SRis 1.8VVT today - exactly the same - something between 3 and 4 seconds and indicator is gone.
    what did i tell you.....
    glad you are able to reassure yourself rather than beleive some bloke on the internet..
    May 2008
    S'port and L'pool
    don't worry - I'm still going to see another 2-3 cars to confirm the confirmation. As I said earlier I have had many cars: Renaults, Citroens, Fiats, Fords, Opels, Toyotas, Volvos and none of them was doing this. Sorry, one was - Polonez but its oil pump was broken .
    Probably oil pressure sensor is in the end of oil circuit and that's the reason for the delay. Whatever - I recon it's better to ask twice then to be sorry
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. ANy ideas? Engine starved on diesel when pressure up
    By geordieric in forum Engine & Drivetrain
    Last Post: 15th September 2012, 12:39
  3. Noise from engine. May be high oil pressure.
    By Shaben in forum Engine & Drivetrain
    Last Post: 18th May 2012, 19:36
  4. vec 1.8 vvt engine oil pressure
    By sjm1966 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2008, 23:01
  5. Replies: 2
    Last Post: 2nd July 2007, 12:14
