Results 1 to 10 of 11
Thread: Not happy with the trumpet in the airbox
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Default Not happy with the trumpet in the airbox
    I had the airbox off tonight to have another look inside.
    I couldn't believe how small the trumpet goes to inside the box.
    Now I am considering just cutting it out, but would need some sort of grinder to take the inside lip off where it meets the airflow meter. I am replacing the throttle body with one 10mm bigger, but it seems like it will be a waste of time if it can't suck more air in the first place. Either that or just get some form of induction kit.
    On a related topic, does anyone know if the airflow meter on the 3.2 will fit my 2.2? As this is the next restriction in size I can see, and I imagine the 3.2 one is bigger?
    Any thoughts, suggestions or opinions welcome.
    yep.. don't don't don't...simple as..
    the intake trumpet is there to provide a smooth linear airflow over the airflow meter..remove it and you get a tumbling mass of air which will give weird airflow readings actually making it perform WORSE than it can...
    the same for the airflow meter.. it will still pass the same volume of air, but the bigger diameter throttle body will mean it just flows at a greater velocity through the MAF than it would have with the smaller TB..fitting the 3.2 MAF will just make it flow the same volume of air SLOWER which will play with the MAF readings and throw the engine into running overrich ..
    a DECENT remap will take into account the values of the existing MAF as the fuelling map is designed...
    Leave it all well alone.. there is more harm here than good.. It's all really down to aerodynamics theory really..
    the only way to get more air in effectively, is to force it in.. be brave, put a hump in the bonnet and whack a supercharger on it...
    Full Member Big Sig's Avatar
    I took that out in my old astra coupe, it was just clipped in and didn't need any cutting at all
    May 2007
    Mate, I would love a SC! Would it be worth fitting a larger trumpet?
    I wonder if thats why you get some running issues with induction kits, as the airflow isn't smooth?
    Some of that is also the fact they draw in a lot of hot air from under the bonnet, unlike the cold air into the air box.
    Quote Originally Posted by Vid View Post
    i'd just leave it as standard for now... bigger trumpet diameter also affects how the air moves..(the lenght reflects the torque the engine makes.. the induction lenght is carefully calculated)
    yep, open inductions do draw hot air in, and hot air is the enemy.. it won't carry as much oxygen and so burns with less power..Closed systems fair better as they have a cold air feed ( denser air, more ability to carry oxygen, more power) But the additional bends rob power, and the corrugated hoses they use create surface shear of the airflow and don't provide a smooth airflow ( thats why all the internals of a VX hoses are smooth ) which again just meets the OEM MAF sensor as a spalling tumbling mass which won't give a good smooth reading
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Removing it will not affect the flow rate just the pressure drop at the MAF and how smooth.
    But on a separate note, the air box mod is one thing removing a part of the air box which is there to prevent turbulent airflow would be daft as at greater engine speeds the air flow is far more violent and hence it starts to heat up - enough to cause poor performance due to the less dense air.
    Gazza4
    May 2007
    Ok you guys win, I'll leave it all alone .
    Cheers for the advice! I was just worried that I could get more power when I have it mapped with a different setup, but it seems gains will be minimal if any!
    At least I'll save a few quid!! But I'm sure I can think of something else to put it towards!
    Thanks again!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Did you spot the mesh on the MAF I was on about Vid?
    May 2007
    Yes I saw that mate, not sure if there is much to gain though mate, looks fairly thin to me? Has anyone else done it before?
  1. Induction trumpet on lower grill
    By justin33 in forum Styling
    Last Post: 28th October 2012, 22:49
  2. airbox top inner trumpet - anyone got one ?
    By pompeydave in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2012, 23:49
  3. Full Hunter alignment - One very happy member and one not so happy
    Last Post: 14th April 2012, 14:08
  4. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  5. trumpet or not??
    By CLOMP in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2010, 20:17
