Results 1 to 10 of 22
Thread: Audio HELP.
    Regular Member shan's Avatar
    Default Audio HELP.
    I've just fitted a DVD player and roof mounted screen to the wife's astra.
    I've used Audio out and run this to speakers in the rear but the sound is VERY low.
    The volume of the player is up to it's max but still the sounds Very low.
    Any idea's ???????
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Purely a guess here but is the audio out at pre-amp levels? I'd have thought that needs to go to an aux-in on the head unit rather than direct to the speakers. That way it gets amplified by the receiving unit and you control volume through the head unit.
    You have lost me on the pre-amp levels. Sorry.
    What i've got is a DVD player "seperate unit" and a roof screen.
    The screen has no speakers in it so i need to install them. I bought 2 bog standard speakers and i will fit them behind the daughter headrest.
    I don't want to mess with the stereo at all.
    I connected the yellow video to the screen and the audio red and white i've wired to the speakers direct.
    Like i say it work's but the sound is Very low. "Unable" to hear it even with the speakers behind the headrest.
    South east
    Are you feeding the speakers power?
    Quote Originally Posted by Rebellion View Post
    All i've done is connected the 2 core's from the red and whito audio
    plugs to the 2 connections on the speakers.
    How would i power the speakers ??
    Jul 2006
    Shan, are the red/white leads from the DVD player just bare wires, or have they got RCA plugs on?
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    I think i know what you have done. The dvd player wont have an amp so you need to power the audio. I will try to make this easy..... The red & white audio leads need to be plugged into a head unit with an audio in... that will power the sound through the car speakers, If say you bought a head unit without an audio in BUT it had a cd auto changer plug you can get a lead that plugs into the autochanger socket on the head unit then plug the red/white audio leads into that from the dvd & then you have sound. I have done it this way in the past..... Hope this makes sense to you mate
    Quote Originally Posted by parapaul View Post
    Yes it had the RCA plugs on it but i cut them off.
    I have more leads so i can put another in with the plugs on.
    Quote Originally Posted by Madgunner View Post
    So i need to buy a headunit ?
    I wanted to avoid that as it's more cost and i don't have anywhere to put it.
    you could just buy a small cheapish amp and use that, then wire it from the dvd to the speakers.
  1. CD30mp3 Twin Audio - No sound on Twin Audio/mini jacks
    By Thomza in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2012, 17:35
  2. FOR SALE: Rear Audio / Twin Audio Controls...
    By Ademusic in forum Parts for sale
    Last Post: 21st February 2010, 19:53
  3. Car audio...
    By dankidd in forum General items for sale
    Last Post: 1st December 2008, 18:34
  4. new audio
    By swalk999 in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2007, 16:24
