Thread: oil warning light
    durham
    Default oil warning light
    i have a 52 plate vectra 2.0 dti the oil light is flickering when idling at junctions, normal temperature, just been serviced any ideas as rather worrying cheers
    oil level or oil pressure?.. i.e. the red oilcan on the dash, or the one in the tacho display??
    if it's level, then thats easily sorted.. if it's pressure then it leads to a few other questions..
    1: who serviced it?
    2: have they 'flushed' it?.. always a dodgy thing to do to engines that aren't used to it..
    3: what grade of oil did they refill it with?
    4: have they installed the filter correctly and changed the lower oil seal o rings when they did it?
    at best, it may just need another service..to change what has already been done.. at worst it may just be the pressure sensor playing up ( the diaphragms in them fail) or it may be something more sinister ( if it's been flushed it could be carbon holding the oil pump bypass valve open)..
    durham
    thanxs for reply was serviced at local garage and did use a flush. however all previous servicing was done by vx and the light was still flashing. i have only had the car for two weeks and never seen the oil pressure light flash on any prevoius cars i have had. the car only 70000 on the clock and fsh so i think it cannot be too serious. the light flashes intermittent and only when the clutch is depressed at junctions and slowing down.
    if it's the pressure light, it could be wiring, but i'd start with a new sender unit ( just screws in) as they do split the diaprahgm. it it still illuminates then it does point to an oil pressure problem. either oil bypassing the filter or the releif valve in the oil pump sticking
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
how to override check oil light vectra c
oil light flashing vauxhall signum site:www.vectra-c.com
