Thread: Longer starting
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default Longer starting
    For the past few days the vec hasn't been firing up as well as it normally does. It used to fire up on the first turn of the key after a second ,A few times the past couple days its needing a second turn of the key to fire up ...anyone any ideas plz thanks.
    It may sound daft but when was it last serviced ?????
    It may just be a case of time for some new plugs and filters (dont forget the fuel filter)
    South east
    And have you switched fuel-supplier recently?
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    I read in the user manual that you shouldnt depress the clutch when starting as it drains power for some reason and could cause it not to start???????? Probably zero help that was it....nevermind.
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    No still using the same fuel supplier, gonna try new fuel filter, and will get some new spark plugs fitted as i cant see any being changed in the sevice history.....btw what are the best spark plugs to get?...thanks
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    just wondering if this has something to do with the car kangarooing in low revs..got it booked for a tech 2 tomorrow hope i get some codes or i am gonna be chasing a ghost..things i have done so far-replaced lambda nope/cleaned maf sensor nope/checked for vacuum leaks no no no ...cars great aint they!
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    My old astra done that to!
    The HT lead change and bobs your uncle
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Depressing clutch is advised in manual under cold conditions as it reduces strain on the starter (ie not turning gearbox too)
  1. No longer Obsessed
    By john_k_sri in forum The 'Off Topic' room
    Last Post: 9th May 2009, 10:38
  2. No longer a sponger.
    By badback in forum Detailing and Car Care Discussion
    Last Post: 18th March 2009, 23:02
  3. can't hold it in any longer.....
    By ditchp in forum The 'Off Topic' room
    Last Post: 4th January 2009, 21:29
  4. Signum... No Longer Available
    By Ross-SRi in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2008, 22:23
