Thread: Blanks Removal - Tomtom
    Home
    Default Blanks Removal - Tomtom
    Does anyone know how you remove the blanks (either side of the radio) that are fitted as I am trying to route a satnav supply up there. Is it also possible to pull the radio far enough out to gain access without actually unplugging it. Thanks all.
    As a by the way as anyone any experience of the quality of sound via the fm transmit (mp3) of a tomtom sat nav, cheers.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by bigearmuffs View Post
    I used two dinner knifes, one at either side of the blank and squeezed the blank very gently (the trim damages easily btw) then gently pulled the blank til it just fell out.
    Gazza4
    Larkhall
    The sound quality of the fm transmitter is quite good, although it depends on what frequency you use and wether you are getting a strong enough signal
    Home
    Cheers Gazza4 and T4M. I bought an MP3 player with FM transmit at the weekend and it is very low quality, hence I have been looking at the Tomtom version (kill two birds with one stone) but I don't want leads all over so I was looking for a route behind the dash for the power. Thanks for the replys.
    [Ex]Admin Duncan's Avatar
    Does anyone know how you remove the blanks (either side of the radio) that are fitted...
    Big blob of blu-tak, push it onto blank and gently pull - blank should release.
    The connector is on the cage, so as soon as you pull the unit out it will have already disconnected.
    Home
    Thanks Duncan, time to find that ball of blu tak.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    How do you mean Duncan - I can get my radio all the way out with it still connected and working.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    If you take the trim strip off the dash & loosen the display/vent housing (2 or 3 screws behind the trim) you can feed the wire up behind the trim strip. I then filed a notch in the end of the trim strip & brought the wires for the TomTom & Parrot out right next to the steering column. They can then be neatly brought round to the TomTom & Parrot
    Quote Originally Posted by vxvirgin View Post
    Ah right, it must differ between head unit models then. On my CCR2600 the plug is attached to the back of the metal cage that the HU slides into, so as soon as I start to pull the HU the plug comes out of the socket on the HU. On yours is the cable with the plug 'loose' and pulls out with the HU? Which HU is it?
    Mar 2007
    Southport
    On the CD30 it's a quadlock connected directly to the radio
  1. key blanks
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2012, 17:55
  2. Key blanks?
    By pogvec in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2012, 23:03
  3. Blanks?
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 19:58
  4. What goes in the blanks?
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2010, 17:07
  5. Dvd blanks!! Price??
    By the-wizard in forum General Chat
    Last Post: 20th April 2009, 00:41
